Originally posted by kamotors
View Post
Kamotors E30-Turbo to ITB M20
Originally posted by ForcedFirebird View PostNot sure, but if I remember correctly, Otis said he had to extend the slave in one of his cars, but can't recall if it was the m50 or m30 car. If the e30 master is significantly smaller, the slave may not travel far enough. It's an easy test to extend the slave rod, and if it doesn't work, just cut it back down.
If the slave hydraulic line is old it will expand causing the same problem also.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
I removed the clutch stop to gain some more travel and it still acted exactly the same. clutch lines are all NEW (soft lines and hard lines).
If the synchros are lined up while vehicle is running but not moving the clutch functions perfect.
When this first happened I couldn't even replicate the problem but now it seems to be every time I stop.
7speedshop.com
Put the stop back in, or at least check travel on master. My buddies e30 lost a master two 14hr races in a row due to over extension. All my OEM manual cars had a plastic stop in them.
Thanks Otis, you had mentioned it when we were trying to figure out Livington's no disengage issue, and that one was a backwards disc fail lol. Seems so long ago.
Originally posted by kamotors View PostClutch is engaging just at about 2-3" off the floor
Originally posted by kamotors View PostI removed the clutch stop to gain some more travel and it still acted exactly the same. clutch lines are all NEW (soft lines and hard lines).
Can you explain this differently? If the engine is running with the trans in neutral and the clutch engaged, no syncros are lined up, they are spinning.
video shows it working at first (basically perfect, smooth, easy to use). Then I roll a couple feet put it in neutral and stop and then it no longer works.
I dont think a back words clutch disc would work this good when it is working. plus the more I look at the E30 clutch it seems impossible to install backwards because the protruding side of the disc would hit the pilot bearing flywheel bolt area.
here is a video
another of just driving and how it works normal when moving.
7speedshop.com
Originally posted by RagtopE30 View PostI am running a 533i spec clutch and a 325i slave an master with no problem
OP, did you lightly grease the splines on the trans input shaft before installing the clutch disk? Maybe there's some binding going on?
pilot bearing maybe? this tends to happen in rx-7's when there either isn't one or it's shot.1991 325i - "Scambles" The Daily Driven lightly modded.
1988 Mazda RX-7 TII "Mako" The Free Dorito
bacon by Jared Laabs, on Flickr
