Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #2191
    Yea at first I thought maybe you just got a lemon but after the second one i dont think i'm going with spec on my clutch setup when i go turbo
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • Bimmer_man
      • Jan 2013
      • 1478
      #2192
      I think spec just lost a lot of business because of your posting on r3v concerning the spec clutch. It's miller maf insesent all over again.
      Float like a cadillac sting like a Bimmer!:)
      • jalopi
        • 2370
        #2193
        Wow... if they don't send you another disc + a $250 refund or offer a full buyback someone in management went full retard. Not sure if they know how many people read this thread... in any case, they're gonna have a bad time unless you aren't.
        Hope everything works out, I'd be fuming if I got dicked over like that
        • Bimmer_man
          • Jan 2013
          • 1478
          #2194
          question. Is it at all possible that the shaft it self is bent? Just saying it is extremely rare to have the same exact issue even with cheap parts which yours are not cheap at all.
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #2195
            But on two diff trannys
            • Bimmer_man
              • Jan 2013
              • 1478
              #2196
              oops didnt realize that it was done on two different transmissions. my bad.
              • downforce22
                • Aug 2009
                • 3193
                #2197
                Have you considered an F1 Racing clutch?
                EDIT: On second check, looks like you won't hit 500 hp/tq with the f1 kit
                • LowR3V'in
                  • 4209
                  #2198
                  ;D Clutchmaster segmented kevlar iz nice
                  U don't need unsprung metal full race disc for only 500tq.
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2199
                    ^ going for more than 500
                    7speedshop.com
                      • 37833
                      #2200
                      Wow! Spec if definitely dropping the ball on this one. How would somebody BEND a clutch disc installing it? :rofl:
                      I need to put a better clutch in my car soon and it's nice to know who NOT to order from!
                      Grover Beach, California
                      BimmerHeads.com
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #2201
                        Installing the trans from below and letting it hang on the input shaft, or using the bell housing bolts to draw the trans in, rather than letting it seat easily on it's own. We have seen it more then once. This is why when Kam explained the symptoms earlier in the thread, first diagnosis I listed was a bent disk. In fact if you search for "clutch won't disengage" and look through threads, tons of them come up where a bent disk was the culprit.
                        john@m20guru.com
                        Links:
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #2202
                          The amount business spec just lost haha
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2203
                            Spec had me take some measurements on the new disk. does this seem excessive or normal?this is how high it sits off the table and its only the one area.
                            IMG_1313 by kamotors@y, on Flickr
                            spec clutch line by kamotors@y, on Flickr
                            definitely excessive by SACHS standards
                            7speedshop.com
                            • jalopi
                              • 2370
                              #2204
                              I think I see what you're talking about, as far as being off axis goes.
                              Sorry we all had to learn at your expense, but I'll definitely be checking my clutches for runout in the future. This really has to be unbelievably frustrating....
                              • rzerob
                                • Jun 2013
                                • 2315
                                #2205
                                I would measure the first clutch disc as well. And compare them. If the measurements are very similar then you have an arguing point that it was bent when you bought it as well. They could both be crap from the same mold that got past quality control. If one got through chances are high that more got through as well. Then you would not lose any money. Or own any expensive paper weights.
