Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #2296
    OMG so jelly but once again wheres the tire smoke?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • kronus
      • Apr 2008
      • 13014
      #2297
      well done.
      how's the lag? still curious what that extra piping to get to the TB is doing to the performance..
      cars beep boop
      • kamotors
        • Nov 2007
        • 7102
        #2298
        Originally posted by kronus
        well done.
        what lag lol, no noticeable lag becuase its strong right off idle and boosting by 3k.
        7speedshop.com
        • IronFreak
          • Dec 2012
          • 3702
          #2299
          Maybe I missed it but what turbo did you go with on the m30?
          Instagram @rebellionforge
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #2300
            Precision 6266
            • Massimo
              • Jan 2008
              • 3207
              #2301
              Originally posted by kamotors
              mmmm, in love with this car again. Words can not describe the sounds that come out of my exhaust setup.
              I need a video with good quality audio so I can enjoy this as much as you
              • rzerob
                • Jun 2013
                • 2315
                #2302
                Ditto.
                • AWDBOB
                  • Aug 2013
                  • 4386
                  #2303
                  How does the spool look in VD?
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2304
                    I get around 1 psi near 2500-2800rpms
                    7speedshop.com
                      • 37827
                      #2305
                      Beast.
                      Classic BMW Specialists
                      Santa Clarita, CA
                      www.BimmerHeads.com
                      • blck325is
                        • Apr 2006
                        • 1749
                        #2306
                        What do we want?
                        TIRESMOKE!!
                        When do we want it?
                        ..as soon as possible kthanksbye :D
                        Originally posted by csermonet47
                        Vlad, you are handling this quite unprofessionally.
                        Also, you are a cock with tacky taste.
                        That is all.
                        • Ray Smoodiver
                          • Jun 2004
                          • 8809
                          #2307
                          Weapons-grade E30.
                          • delamaize
                            • Nov 2013
                            • 1430
                            #2308
                            Originally posted by ray smoodiver
                            weapons-grade e30.
                            +1
                            Dumpster Fire Pilot
                            • MatRacer
                              • 562
                              #2309
                              Coming here like 6 times per day to hear this beast! Good job on keeping this car evolving! really motivating!
                              E30 now S52
                              2008 Suburban LTZ (Family and TT hauler)
                              325xiT (Sold)
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2310
                                lol here's a quick tease, car was far too rich and laptop was down, so retuning today to hopefully get some better footage. I'll be making a video with multiple clips and driving by tomorrow night.
                                was running at 10.2 at WOT, retuning to around 11.8 today.
                                Also messed with it enough to find a ghetto boost by gear setup. The reason it works is due to running low psi WG spring + large A/R hot side which results in high gear overboosting that I can actually control to a point. So this setting is definitely the fastest out of the hole.
                                My choices are either lots of boost every gear with no over boosting or use overboosting to get me to target boost in high gear and use the MBC on WG to control low gear boost levels.
                                9psi-first gear
                                14psi-second gear
                                17psi-third gear
                                21psi-fourth gear
                                7speedshop.com
