Kamotors E30-Turbo to ITB M20
  • MF DOOM
    • Apr 2012
    • 944
    #3046
    I always look forward to checking this thread. I can always count on updates.
    • Good & Tight
      • Apr 2004
      • 2057
      #3047
      Boost is an addiction, once your hooked you gotta have it. The itb's sounded sweet but after seeing how you hammered your turbo M30 setup I knew it was only a matter of time you'd be back with a boosted setup.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • yert315
        • 2734
        #3048
        Make a plenum and boost with ITB?
        • kamotors
          • Nov 2007
          • 7102
          #3049
          Spoiler is 90% done just 2 more supports and it should be good to go.
          I just vinyl wrapped the trunk. (its way too bright but for now it will do)
          Sent from my SM-N900T using Tapatalk
          7speedshop.com
          • efficient
            • Feb 2012
            • 3312
            #3050
            You should do a diy tutorial for a turbo setup. Just saying
            • kamotors
              • Nov 2007
              • 7102
              #3051
              Deal!
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #3052
                $9 e36 picknpull skirts, $10 of paint, 1hr of freetime and she lost a total of 8.2lbs, which i found hard to believe but 72"x3" thick of 80s rubber/foam is heaveier than you'd think!
                98.3lbs to go!
                7speedshop.com
                • IronFreak
                  • Dec 2012
                  • 3702
                  #3053
                  How much did you have to trim? I have a pair as well I was thinking about using. They seem to be a few inches long though.
                  Instagram @rebellionforge
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3054
                    Not sure how much, just held upto car and trimmed. Id say like 7"
                    Then just reattach end piece with plastic weld/rivets and make aluminum brackets so it flares out.
                    7speedshop.com
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      #3055
                      Always cool to see your updates. Your E30 looks - and pulls I bet - like a freight train.
                      How did you accomplish your monowiper?
                      ACS S3 Build / Dinan 5 E34
                      • blck325is
                        • Apr 2006
                        • 1749
                        #3056
                        In for a template to that rear spoiler.. and looking forward to the new turbo setup. You gonna stick with the setup you had before or are you gonna change it up?
                        Originally posted by csermonet47
                        Vlad, you are handling this quite unprofessionally.
                        Also, you are a cock with tacky taste.
                        That is all.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #3057
                          it'll be a combination of the M30 setup and my old M20.
                          7speedshop.com
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #3058
                            Sticking with the same precision 6266?
                            1991 318i 4dr slick top
                            Mtech 2 turbo restoration
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3059
                              I already sold that off. I have a new 20g sitting here but i wanted to try a t4 turbo out so not sure if ill use it.
                              7speedshop.com
                              • 2mAn
                                • 20059
                                #3060
                                :ST1G: because ST1G quoted me the same way
                                Originally posted by bullet ride
                                you have a bad case of vehicular adhd lol
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
                                -2006 Volkswagen Jetta TDI
                                Make R3V Great Again -2020
