OMG so jelly but once again wheres the tire smoke?
Kamotors E30-Turbo to ITB M20
Maybe I missed it but what turbo did you go with on the m30?sigpic
Instagram @rebellionforge
Originally posted by IronFreak View PostMaybe I missed it but what turbo did you go with on the m30?
Precision 6266
Ditto.Originally posted by Massimo View PostI need a video with good quality audio so I can enjoy this as much as youHow to remove, install or convert to pop out windows
Weapons-grade E30.
lol here's a quick tease, car was far too rich and laptop was down, so retuning today to hopefully get some better footage. I'll be making a video with multiple clips and driving by tomorrow night.
was running at 10.2 at WOT, retuning to around 11.8 today.
Also messed with it enough to find a ghetto boost by gear setup. The reason it works is due to running low psi WG spring + large A/R hot side which results in high gear overboosting that I can actually control to a point. So this setting is definitely the fastest out of the hole.
My choices are either lots of boost every gear with no over boosting or use overboosting to get me to target boost in high gear and use the MBC on WG to control low gear boost levels.
9psi-first gear
14psi-second gear
17psi-third gear
21psi-fourth gear
7speedshop.com
