Kamotors E30-Turbo to ITB M20
  • dugly52
    • Oct 2012
    • 372
    #3061
    Originally posted by efficient
    You should do a diy tutorial for a turbo setup. Just saying
    In for this!! Starting a turbo build this winter. Always nice to have some bread crumbs to follow.
    Project: 87' 325iS... 325iS
    88 Alpine 325i
    1/2 88 325iX
    • Coyote_ar
      • Sep 2009
      • 175
      #3062
      or make it a video DIY tutorial, upload it to YT, monetarize it and get some cash for those views ...
      many guys seem to be getting some cash and sponsors for that kind of thing.
      ---E30 320i Hennarot 1984 Sedan---
      • kamotors
        • Nov 2007
        • 7102
        #3063
        Pulled out the itbs and got the oem manifold ready. I plan on doing a few diy videos for example how to install oil filter relocation kit, how to install/ clock turbo, oil lines etc.
        Intake manifold is gold basecoat, charcoal, then clear. Looks amazing in person. Camera couldn't captue how it changes in light.
        Sent from my SM-N900T using Tapatalk
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #3064
          7speedshop.com
          • efficient
            • Feb 2012
            • 3312
            #3065
            Dang man you move too fast. Wish I could start on my turbo build
            • kamotors
              • Nov 2007
              • 7102
              #3066
              Some mild progress. Car's so nasty right now :(
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #3067
                So 10.6lbs removed by cutting out sheet metal valance and deleting oil cooler but then i added the intercooler which is a whopping 15.8lbs.
                So weight gain of 5.2lbs.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #3068
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3069
                    New good-n-tight manifold installed 30min after delivery. Nice fit, some studs get real close to piping so make sure all nuts are installed before you tighten it up!
                    7speedshop.com
                    • Good & Tight
                      • Apr 2004
                      • 2057
                      #3070
                      Damn Kam, you don't mess around, looks great....!!!!
                      Good choice on using the stock exhaust gaskets, the ones supplied with it are not so great.
                      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                      ____________________________
                      E-mail Panayiotisx2@gmail.com
                      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3071
                        I know they blew out on my M30 in less than 900miles!
                        7speedshop.com
                        • Northern
                          • 5071
                          #3072
                          I'm sure you know this and have a reason not to, but you could save some more weight if you run the charge piping under/behind the high beams. IMO it makes charge piping way simpler too.
                          Originally posted by priapism
                          Originally posted by shameson
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3073
                            I've always run it under the high beams but I want better cooling for the radiator this go because in LA, or 100degree plus stop and go i was not getting adequate air flow. Now im able to fit 2 fans both at 3.5" thick now. It was done for a reason;)
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3074
                              Precision 46mm wg at 7psi and testing a 20g, however im going to go with a t4 turbo.
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3075
                                7speedshop.com
