Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #3331
    Originally posted by Bimmer_man
    I think you need to get yourself a second e30
    i've been shopping, really want to builds a turbo e23 w/ flares
    7speedshop.com
    • Bimmer_man
      • Jan 2013
      • 1477
      #3332
      That would be sick man. Would it be a monster or just a nice cruser?
      Float like a cadillac sting like a Bimmer!:)
      • kamotors
        • Nov 2007
        • 7102
        #3333
        Kamotors does not cruise
        7speedshop.com
        • Bimmer_man
          • Jan 2013
          • 1477
          #3334
          So it is going to be a turbo manual swap 7 Series
          • kamotors
            • Nov 2007
            • 7102
            #3335
            Yup, just imagine a flared out, boosted m30b35, 5 speed manual e23 lol. It'll be different for sure.
            Sent from my SM-N920T using Tapatalk
            7speedshop.com
            • Bimmer_man
              • Jan 2013
              • 1477
              #3336
              Not to mention balls out fast just your style
              • kamotors
                • Nov 2007
                • 7102
                #3337
                New video of the first drive on this setup.
                7speedshop.com
                • Blake B
                  • Feb 2015
                  • 150
                  #3338
                  What's in the v2 kit?
                  1990 325i Cashmere Beige
                  "I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3339
                    I guess its whats not in the kit... Basically I shortened overall piping by around 2feet, lost around 5 couplers, gained valance clearance and made the kit 10x easier to install. Turbo and main components are the same
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #3340
                      V2 turbo kit available today
                      AVAILABE AT KAMOTORSPERFORMANCE.COM
                      7speedshop.com
                      • Northern
                        • 5036
                        #3341
                        Finally running charge piping under headlights? I know you like to run 3" charge piping, which makes it harder, but the fewer bends/restriction, less ic volume to pressurize, less weight, and fewer failure points make it very attractive.
                        EDIT: and where did you find that turbo intake boot/PCV port? I can't find anything like that.
                        Originally posted by priapism
                        Originally posted by shameson
                        • Garage30
                          • Aug 2015
                          • 123
                          #3342
                          Sweet setup! How much meth are you spraying? To what afr?
                          Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
                          Instagram: @garage30_ WWW.GARAGE30.NL
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3343
                            I don't remember the exact injector sizes but its a cooling mist 400hp nozzle and the biggest injector aem includes in there dual kit. Same as it was the setup on my m30. I'm running 11.5afr for now. The guy dynoing the car said he likes to run cars at 20 degrees timing and 12.0afr on meth.....let me tell you that doesn't work on m20s lol.
                            7speedshop.com
                            • Garage30
                              • Aug 2015
                              • 123
                              #3344
                              So you are spraying a decent amount I'd say. Any guess on how much of the afr is meth?
                              I'd like to go with meth for a m20 turbo car im building, because E85 is not available anymore here. I was thinking to tune it to around 11.5/12ish on 91 and use meth to spray it down to 10.5 ish, considering alcohol doesn't rob much torque being rich.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3345
                                Actually just had to downsize one nozzle, it was quenching combustion, it was coming on too early and at full power causing it to be severely down on power in gear 3-5. But fine in second as that gear raps out fast. It was fine on a big thirsty m30, but too much for the m20, I've got to retune it now and make sure it's good or I'm just going to get a fancy progressive setup and run a single injector.
                                7speedshop.com
