Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #3481
    Originally posted by 86gt635
    That's impressive how quickly you were able to do that, it looks perfect. The detail on the part number is clean.
    You join the pieces together with resin?
    Backside of each cut has been completely reinforced with fiberglass and epoxy resin. It's nice and strong as original. I got really luck with the part number as my cut went directly through that, but it all lined up perfect and looks original still.
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • 2mAn
      SeƱior Mod
      • 20376
      #3482
      onward and upwards man. good luck in the next phase. and quick awesome work on the valence
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • 86gt635
        • Jun 2012
        • 99
        #3483
        Very clean work, I'm sure I would have made a mess trying to work resin into the seams. Initial fiberglass work is really easy to make ugly. "The less you touch-the less to sand"
        The cuts were so clean, standard grinder cut off wheel or did you use a hacksaw blade? That's just really good work man.
        I'm working on a m635 front spoiler and have been doing a bunch of fiberglass work on it.
        I'm really sorry about your Father man, Stay strong. I'm losing my Grand Father right now due to stage 4 throat cancer. His little brother passed last year from it. Fuck cancer.
        • kamotors
          • Nov 2007
          • 7102
          #3484
          did all cuts with a dremel cut off wheel; and yeah F cancer..
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #3485
            Such a sad state, I've gone over how long it would take to get the car back together naturally aspirated and it doesn't look like I'll be done before bimmerfest...
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #3486
              oh how I miss this.
              7speedshop.com
              • rzerob
                • Jun 2013
                • 2315
                #3487
                Does that mean you are going ITB again on your next rebuild?
                • kamotors
                  • Nov 2007
                  • 7102
                  #3488
                  Filmed the process of re-turboing my E30. Was able to weight reduct like 200lbs out of the setup and drastically reduce the center of gravity. https://www.youtube.com/watch?v=Eap-a8n0eHs
                  7speedshop.com
                  • stonea
                    • 2892
                    #3489
                    I thought that said 20 lbs instead of 200 and thought this was a serious video....
                    My Garage
                    Feedback
                    Instagram: Stone.Hopkins
                    • bradnic
                      • Jul 2012
                      • 3550
                      #3490
                      that vid is an absolute riot man. props
                      HOWTOs:
                      DB vert plastic bumpers
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • bangn
                        • Sep 2011
                        • 760
                        #3491
                        I like the bit where the cover got put back on the deck.. JOB DONE
                        Boris - 89 E30 325i
                        84- E30 323i
                        • potatomash
                          • Nov 2014
                          • 203
                          #3492
                          Hey Kam, have you still got this dyno? Ive got a garret gt3582r ball bearing and wondering if I'm gonna be wasting my time
                          Thought this was interesting for E30's running huge turbos.
                          The RED graph is my E30 in FIRST gear with an M20, gt35 turbo, stock intake manifold and 274/280 camshaft.
                          The BLUE line is my current Naturally aspirated M20 setup in FIRST gear with same cam/internals, rhd itb's, short/mid length headers, X pipe near trans and dual 2.25" piping to the subframe. Picked up considerable amount of N/A power under peak.
                          Now to go tune the ignition map.
                          T U R B O - M 2 0 - B U I L D
                          M U S C C O O
                          • bradnic
                            • Jul 2012
                            • 3550
                            #3493
                            SO it was worth it to know they are all reasonably synced now, however still backfiring!, I can look down the trumpets and see flames:(
                            here is a quick how to as its very simple.
                            #1 need to have access to vac lines for each runner( I did this all preemptive in hopes of a bit of speed density driveabilty and knowing it helps tuning)
                            #2-locate your adjusters
                            #3-setup your sync tool and get other tools needed like a flat head screw driver, allen wrench and an 8mm.
                            #4-calibrate your tool off of the NON adjustable set(cyl.5 and 6).
                            #5-calibration done (close enough)
                            #6 hook up your ITBs to each port mine were very far off.
                            #7 tuned to around 1300rpms about as close as I could get them.
                            however uploading video of how bad it still pops just holding rpms around 3k.
                            video
                            Kameron pics are not showing on alot of these older posts.. Looks like they were posted to facebook? would love to see this one in particular
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3494
                              Not having my e30 is driving me a little crazy. Here's a stupid video I made while replacing the oil pan on our group rally car build. So far we've flushed 10qrts of oil through it but going to remove pan again and ensure its actually clean.
                              7speedshop.com
                              • efficient
                                • Feb 2012
                                • 3312
                                #3495
                                "Wow"
