Kamotors E30-Turbo to ITB M20
  • wazzu70
    • Jan 2005
    • 1143
    #841
    The timing map is incredibly critical for transient response and spool. Get your timing dialed in and the car will feel much better!
    -Nick
    M42 on VEMS
    • kamotors
      • Nov 2007
      • 7102
      #842
      some pics from car show today and some birthday burnouts
      7speedshop.com
      • wazzu70
        • Jan 2005
        • 1143
        #843
        Any chance you could give a straight on pic of the front? Im curious to see how much the flares stick out compared to OE.
        Thanks!
        -Nick
        M42 on VEMS
        • kamotors
          • Nov 2007
          • 7102
          #844
          flare size up front
          7speedshop.com
          • DEW
            • 26
            #845
            Gotta love those MysterE heads. That thing must be insanely fun!
            • darvo
              • Dec 2010
              • 407
              #846
              Got a youtube link for the new vid?
              • kamotors
                • Nov 2007
                • 7102
                #847
                sorry I dont, I'll make a new video. I did some brake boosting today and I can get full boost before I let off the brake:)
                7speedshop.com
                • Cronopoulos
                  • Jul 2011
                  • 2187
                  #848
                  Check valve clearance?
                  Project log -- DIRTY 30
                  2.7i * Megasquirt tuned * E85 powered
                  • ak-
                    • 12422
                    #849
                    Originally posted by kamotors
                    also I seem to of grown a ticking fuel injector, I listened around for a good 10 minutes under the hood and it doesn't seem to be coming from the valves, its a slower tick. noise does not increase with oil cap off.
                    is it something to worry about? car runs fine.
                    Well injector tick is considered normal. It's probably more apparent to you now because you are actually trying to notice it this time around.
                    Take a stethoscope to it and confirm.
                    Sure its not a manifold leak? Something that's louder in cold climates (NV??)
                    1991 325iS turbo
                    • kamotors
                      • Nov 2007
                      • 7102
                      #850
                      I double checked the manifold and it seems to be sealed nicely, if its valve tick it sounds as if its only one valve out of adjustment becasue of the speed of the tick. It may just be that I'm hypersensitive to noises since i have all this hard work dumped into the car.
                      seems to be coming from the very rear of the VC/ fuel injector area, I can only hear it below 2krpms.
                      7speedshop.com
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #851
                        After you do a ton of work you get hypersensitive as you said. Injectors are fairly loud so its very possible that is your problem.
                        Thanks for the pictures! Nice looking car :)
                        -Nick
                        M42 on VEMS
                        • ak-
                          • 12422
                          #852
                          Hypersensitive! That's the word I was looking for. I'm the same way, lol.
                          My small manifold leak goes away above 2krpm. Maybe other noises cancel it out + heat.
                          If the engine is cold, and permits my hand being millimeters close, I can feel the pinhole leak out of the manifold.
                          1991 325iS turbo
                          • kamotors
                            • Nov 2007
                            • 7102
                            #853
                            a quick now and before shot and a new pic of my vinyl wrapped shadow line trim.
                            7speedshop.com
                            • JCarp90
                              • Feb 2011
                              • 1759
                              #854
                              ...damn
                              • kamotors
                                • Nov 2007
                                • 7102
                                #855
                                sooo, should I do an alpina 162 front spoiler? like this
                                7speedshop.com
