Kamotors E30-Turbo to ITB M20
  • efficient
    • Feb 2012
    • 3312
    #1351
    they should redo your drive portion on youtube now that you have a bbk.
    • IronFreak
      • Dec 2012
      • 3702
      #1352
      Originally posted by TheTacoMan
      Question is where can you get a quality lightweight 17in 4x100 wheel that wider than 8 inches? Its hard to find these it seems, Ive been looking as well.
      Works wheels....
      Instagram @rebellionforge
      • Not_the_stig
        • Feb 2014
        • 14
        #1353
        I have 17x9 4x100 racing dynamics and they are pretty light
        Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
        • JCarp90
          • Feb 2011
          • 1759
          #1354
          There's a supplier on ebay somewhere, don't remember the name who sells Team Dynamics wheels and he says he can custom order them to just about any size.
          • TheTacoMan
            • Nov 2011
            • 2308
            #1355
            Found some, may have to go this route myself.
            Das wheels
            • kamotors
              • Nov 2007
              • 7102
              #1356
              so got the brakes done; lost a bit over 5lbs per side with the UUC setup!
              I decided to get the new fluid into the clutch system while I was down there ended up messing up the clutch system pretty bad. fluid flows out of the slave just fine, but the peddle will not build pressure and just flops around freely. I've bled 4-5 clutch s,(mine 3 times) and never had issues like this. I ran 32oz of fluid through the slave and it wont build pressure.
              7speedshop.com
              • efficient
                • Feb 2012
                • 3312
                #1357
                have you tried to reverse bleed it or vacuum bleed it?
                • DrLeadFoot
                  • Aug 2011
                  • 461
                  #1358
                  I've bleed 2 clutches and those times it was magic when they caught and started to build pressure.
                  Sent from my SCH-I535 using Tapatalk
                  Instagram: @DrLeadFoot
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #1359
                    Felgenwerks wheels
                    • Bullet Ride
                      • Dec 2010
                      • 598
                      #1360
                      I had issues with mine too when I replaced the slave. What I did that I found worked was with the slave hanging down I removed the bleed screw, pushed the piston in all the way and held it there. Then reinstalled and tightened the the bleed screw. Then released the piston. It's a bit tricky to do on your own. A second set of hands helps.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1361
                        Bought a power bleeder and fixed the clutch, its actually 100x better than it was previously, much stiffer and more progressive.
                        and now my review on the brakes.
                        Overall I love them but there are some things I dont like about them.
                        Pro- they stop amazing, look great and lost a total of 11lbs overall. Exactly what I was looking for.
                        CONS-
                        -#1-Biggest con is the stupid spring clips that hold the pads in. the consistently loosen up and move into the rotor and make a terrible noise. I bent them to fit tighter but they still moved a bit after a good drive.
                        -#2-Second con, the rotors seems to be out of true. At over half braking pressure I now get a shimmy that is a bit frightening. I torqued and locktited everything to UUC's specs but still have these small issues.as I rotate the rotor there is a small section of it that contacts the pad as I spin, same on both sides.
                        I did this to bed them.
                        "1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
                        2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph."
                        I'll report back after more driving but those are my initial impressions.
                        In other news I killed my falken tires. they went from like 40% tread this morning on the rear down to nothing on the inner camber area and after one donut and a rolling burnout they were down to nothing:( so I think I'll grab some news wheels and tires.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1362
                          7speedshop.com
                          • wazzu70
                            • Jan 2005
                            • 1143
                            #1363
                            http://www.rimstock.co.uk/ for team dynamics wheels.
                            -Nick
                            M42 on VEMS
                            • kamotors
                              • Nov 2007
                              • 7102
                              #1364
                              think I'm going to run turbo style wheels. 4x100 and 8.5" wide, and concave, everything I want
                              7speedshop.com
                              • JCarp90
                                • Feb 2011
                                • 1759
                                #1365
                                doitdoitdoitdoitdoitdoit
