316 superlite
  • Skarpa
    • Jan 2013
    • 495
    #241
    Looking good.
    E30 Armo "330i"
    • petrolhead
      • 421
      #242
      Originally posted by 2mAn
      Im loving this build. The color has really grown on me too. Hope you hit all your goals
      As one can see, in every pic the color is different. Yeah, although it shouldn't matter to me, it's nice to hear I'm not the only person who likes it.
      My targets will be met and exceeded, given time. :)
      Skarpa, kiitos!
      • petrolhead
        • 421
        #243
        We put in an empty spare block with an E30 oil pan, spare head and the transmission. Just to see what the propshaft length needs to be. I took the prop shaft stuff with measurements to a machine shop today.
        I fabricated engine mounting brackets but they're so ugly no one will see pictures of them. They're strong enough and that's it. I made them from random stuff available in the garage corner. Different steels, different thicknesses.. so the welding is not going to be pretty.
        Pile of random small stuff that arrived from the dealership
        I took the car out to give it a quick wash. The clip shows it's color/shade well http://petrolhead.kuvat.fi/kuvat/198...side+color.MP4
        • petrolhead
          • 421
          #244
          DIY shifter. Took me a whole saturdays worth of work..
          Feels quite good, and it IS adjustable if need arises. I need to replace a few bits in the linkage to get everything tight. I used what I could from OEM parts. Stick itself is pressed to a spherical bearing. The bearing sits in a weld cup or whatdoyoucallthem.
          • petrolhead
            • 421
            #245
            Quick 'n dirty solution to make room for the plenum..
            If you look closely you'll see the dip stick setup I made. In an old block such as this, the dip stick pipe is with a bolted on flange. So, take the flange, weld a short bit of M40 dip stick tube to it and shorten the stick as needed. I made them real short to save weight, but they might as well be because the inlet side stuff take up a lot of space.
            • Panici
              • Dec 2009
              • 2570
              #246
              Paint job looks great! I'm a fan of bright colors. I also like that you stripped everything inside and out, so that it all received a proper coat of the new color.
              How much work was pulling/reinstalling the fusebox? I guess you are going through the whole harnes anyways to shave weight.
              • petrolhead
                • 421
                #247
                That's the only right way to do it, strip everything before paint shop especially when changing the color. Otherwise it'll look like a trash can. Too many of those circling the neighbourhood.
                Removing / installing fuse box equals removing and installing the main wiring harness. Which in the case of a modest 1984 carb model with no options means 8,3 kgs of electrics stuff. You just put the box in the engine bay somewhere and start feeding it's wires through the big oval hole till you come to the big ass grommet.. Idunno.. not a huge undertaking if the car is without it's dash, engine 'n stuff.
                One thing I would do if I were starting again: Mark the wiring/terminals what they do, every_single_one. And mark them so that they stay on when you pull the bunch out through the firewall.
                I did that and dropped ~1,3kgs of misc wiring off the car. Couple other reasons for this: Ground points and especially ground distributions are prone to bad connections and corrosion. Got rid of those. Shortening the ground wires minimizes voltage loss (circuitry resistance? I don't know the tech terms..), so your lights may shine a bit brighter. I re-routed so much of the wiring that it's all the same to take wiring sets apart, shorten everything as needed and install with new terminals. I did come across many potential faults and bad repairs by previous owners.
                • petrolhead
                  • 421
                  #248
                  Quick solution for a 2->1 collector. Good enough for my purposes...
                  Place to bolt on the coil
                  Exhaust stuff pretty much done
                  Still haven't figured a practical use for the titanium I have lying around
                  The shifter... linkage was shown in one of those^^ pics
                  Stick side of things:
                  I bought a bar of polyacetal and I'm making the linkage bushes from that. Shitty material to work on but stiff bushes.
                  Sold the only tyre/rim set I had, from under the car. I ordered a set of semi slicks, hard.
                  I got the prop shaft back from machine shop, balanced 'n all! They even included a new center bearing, yay!
                  • Rob Daman
                    • Sep 2014
                    • 104
                    #249
                    nice work. i like those louvers in first page
                    • Ryan335
                      • Jul 2015
                      • 45
                      #250
                      Some serious dedication here sir, good job. The first picture of the yellow startled me but there is a real depth to that color, changes a lot with the lighting and looks pretty BA!
                      Also, why not fab up a dual shear set up for the shifter? I like the floating spherical but with the arm length you're putting a ton of leverage on that threaded rod/weld.
                      Interested to see how you make the delrin bushings ;)
                      Keep it up!
                      • evoDRichie
                        • Jan 2010
                        • 1743
                        #251
                        awesome work
                        • petrolhead
                          • 421
                          #252
                          Keep it up!
                          It has some leverage, yes, but the total pushing-pulling force required to engage a ratio is no bigger. Not worried about the weld, if they break they weren't proper work. The threaded part is from a 10.9 hard bolt. Anyhow, I'm not worried about their strength or stiffness. Not slamming the gears in and breaking the box is what I need to remember.
                          I used a hole saw to cut approx right size piece of the delrin. When I got it to the right O.D. I pressed it in and drilled the 10mm center hole. I have no lathe.
                          Thanks again to everyone for the compliments.
                          • tonton
                            • Jan 2008
                            • 128
                            #253
                            ootko kurkannut millainen ja miten yksinkertainen systeemi e30m3:ssa on
                            toi laatikon vivusto. miksi et sitä tai vastaavaa käytä?
                            e30_cabrio_336[/URL]
                            • petrolhead
                              • 421
                              #254
                              Nopeesti bmwfanssia kurkkaamalla, aika samanlaiselta näyttää kuin muissakin malleissa.
                              Tossa mun systeemissä nivel on korkeemmalla jolloin kepin saa rattia lähemmäs, ja alalenkki pystyy olemaan tosi pitkä ilman että ottaa kardaaniin. Mun setupissa on laatikonpään kiinnitys täysin jäykkä joten siinä on yksi välys heti pois. Tossa systeemissa pienet klapit kertautuu ja keppi on helposti soppakauha.
                              Oletus on että kardaani, siirtovivusto ja putkisto menee jollain tasolla uusiksi kuitenkin jossain vaiheessa. Haluan saada tota moottoria paljon taaksepäin. Nykytilanteessa moottori on asennettuna niin taakse kuin E36:n hammastanko ja E30:n öljypohja sallii, joten en olettanut tietenkään että mikään OEM-osa olisi sopiva pituudeltaan.
                              • petrolhead
                                • 421
                                #255
                                New O-rings to the sync screws
                                Individual vacuums connected to eachother, from there on the line goes through a filter and then divides to MAP sensor and fuel pressure regulator.
                                Between throttles 1-2 and 3-4 theres a distribution piece which was missing an elbow pipe. Can't be bought separately I believe and the distribution piece is NLA. So, a DIY solution
                                ^Idle control valve connects to that.
                                One hose for ICV, the other for idle ajustment. If I remember correctly, the idle adjustment/check is done with a warm engine and with the ICV disabled.
                                Air intake system, work in progress
                                Engine wiring harnesses pretty much done. The idea is that the whole engine electrical system plus wiring can be assembled to the motor while it's out of the car
                                ..they plug on to these
