Bye Bye Mazda, Hello Bimmer!!!-91' MtechII AW/SW BAR'd S52/SC
  • KoKoSe7eN
    • 253
    #331
    RE: Let's do the engine!
    Rms 6-rib 6"crank, lucky enough to find one...
    Installed! With new AC Belt
    New green top 42lb bosch injectors
    New porsche 3.5" maf
    And the tune
    • KoKoSe7eN
      • 253
      #332
      Boost leak tester, found boost leaks around my whole intake... After 3psi, leaks were pronounced...
      Soooo... Need to reseal intake to hold some boost
      Main leak was ofcourse the icv/pcv coupler, so sanding away to jb weld it permanently
      Make sure it's upside down when curing so the epoxy can evenly seal around the base. Jb weld is very fluid...
      O-ring for FPR
      • KoKoSe7eN
        • 253
        #333
        Just some sensors while I'm in
        Make sure T-clamps are used where possible, my old screw clamps couldn't hold past 6psi. After retest, intake can now hold 15psi solid
        Old bremi's
        New bosch
        • KoKoSe7eN
          • 253
          #334
          Boost!!!
          Originally posted by pandaboo911
          Any problems with belt slip? I was gonna run a grip coated 2.87 pulley hoping for 12 psi.
          Boost gauge!!
          About 13psi at redline reliably with my setup, 6" crank and 3.25" pulley.
          • Coyote_ar
            • Sep 2009
            • 175
            #335
            such a nice build :)
            ---E30 320i Hennarot 1984 Sedan---
            • GnarShark
              • Sep 2014
              • 57
              #336
              never thought about dying carpet :popcorn:
              • pandaboo911
                • 2070
                #337
                13psi from a 3.25 pulley! that's pretty damn good.
                How much did the TRM tune run you? Did you dyno it or did they just send you a base tune?
                My bracket is designed to utilize the stock auxiliary belt so I'll have to stick with the 5.25.
                • KoKoSe7eN
                  • 253
                  #338
                  sad times guys :(
                  headgasket blew!!
                  driving in traffic and didn't notice my temp gauge on red!, found aux fan
                  resistor just went out. had no cooling to my radiator, had the heater on blast and pulled over... but too late the damage was done. burning coolant, now I have a steam engine lol
                  Car now just sitting here
                  • KoKoSe7eN
                    • 253
                    #339
                    Removing engine, decided to do a full overhaul.
                    • pandaboo911
                      • 2070
                      #340
                      That sucks. I recommend you send your head to APM Custom Engines in Morgan hill. Felix did my head for $325. Recut valves with a 3d cutter, valve seals and resurfacing.
                      Glad I did a resistor delete ^.^
                      I'm running 15 psi on a stock headgasket without orings and no problems so far. I'm on e85 though.
                      • pilotskillse30
                        • Dec 2006
                        • 1957
                        #341
                        Epic build. Sorry for the steam engine.
                        • AdOz
                          • Jun 2015
                          • 114
                          #342
                          That boost gauge is awesome!
                          Great build
                          TURB'02
                          INSTAGRAM
                          • 2mAn
                            Señior Mod
                            • 20992
                            #343
                            Sucks about the explosion
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • KoKoSe7eN
                              • 253
                              #344
                              Let's get a LIFT!!!
                              this thing weighs a TON!!! needed an engine lift to take it off of U-Haul
                              Jacking one side just to remove shipping bracket
                              Drilled 12 holes 6" deep, then torqued every nut
                              Test Lift on Alpina e38
                              • 2mAn
                                Señior Mod
                                • 20992
                                #345
                                Is that as high as it will lift the car?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
