'91 318is, 16V swap.
  • e30nub
    • Jun 2008
    • 1741
    #46
    Originally posted by FunfGan
    Well yeah, after I get it running I'm doing polly everything in the back.
    I would reinforce as well as poly. Just replacing the bushings isn't necessarily reinforcing, unless I'm missing something.
    Good luck with the swap.
    -Pierre
    1987 535is
    1988 325is
    • slammin.e28
      שמע ישראל
      • 12054
      #47
      Originally posted by dannyr
      so what's the biggest pita of this swap?
      302.
      • FunfGan
        • Jan 2011
        • 4958
        #48
        Originally posted by DannyR
        So what's the biggest pita of this swap?
        Wiring. Easily. Everything else is pretty easy so far, as long as you don't keep a/c, p/s or heat.
        I'm also planning on doing all the little reinforcement tabs and such, this thing is going to get some abuse. And thanks.
        302.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • DannyR
          • Dec 2010
          • 11
          #49
          Don't you have to bash the shit out if the trans tunnel? I know that e30v8.com makes oil pans. And its a bitch to keep the p/s?
          • tjts1
            • May 2007
            • 1851
            #50
            Originally posted by lolcantturn
            Have you ever considered resale value on such a project? Ford 302's are cool, but no one is going to by a ford powered BMW
            Just my two cents...not trying to be a dick here
            I'll buy it.
            • FunfGan
              • Jan 2011
              • 4958
              #51
              Just a slight bit on the on the e30, the e36 seems to need a lot more for some reason... And yeah, their oil pans are $205 which isn't bad, but I just bought one for $50 from Summit racing, I have some spare steel lying around so I figure I'd save $155 and modify 1 myself. and not sure, I don't think its that hard, the guy who runs e30v8.com kept his. He sells a $70 cd that breaks the whole swap down very simply, even gives the exact dimensions for modifying the oil pan and how to keep p/s, a/c and heat. Heat is easily the toughest though.
              Go here be happy!
              • DannyR
                • Dec 2010
                • 11
                #52
                Yea I've talk to him on Facebook. He told me its easier to run a/c on an e30 then a e36. Thanks for all the help. Your car is going to be a beast good luck bro
                • FunfGan
                  • Jan 2011
                  • 4958
                  #53
                  Thanks man, I'll(hopefully) be done by spring so if you need any other help just pm me. That is, I assume you're doing/ considering the swap?
                  Go here be happy!
                  • DannyR
                    • Dec 2010
                    • 11
                    #54
                    Yessir I plan to do this. It's going to be a weekend/drift car. Just trying to figure everything out first.
                    • 1BadE30
                      • Aug 2011
                      • 41
                      #55
                      No it does not. If it still has all the parts on it in those pics you're no where near 400tq.
                      You'd be lucky if that cast iron e7 head, stock intake fox 302 is even making anywhere near the stock rating of torque. :cockbloc:
                      Mine now has about 400 at 2600rpm... crazy huh? I think I need to reinforce the rear end, and tires.
                      • lolcantturn
                        • 4588
                        #56
                        This thread does NOT deliver.
                        Originally posted by TSI
                        OEM+
                        • e30orDie
                          • Jul 2010
                          • 52
                          #57
                          Smartest statement in this thread
                          :hitler:
                          • FunfGan
                            • Jan 2011
                            • 4958
                            #58
                            So if they run 325ft/lbs stock, and this thing is has a cam and a few other things, what would you guess its running?
                            Go here be happy!
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #59
                              Terribly sorry:( We can't all swap engines and build cars in one weekend.
                              Go here be happy!
                              • Dj Buttchug
                                • Jun 2010
                                • 7686
                                #60
                                im here for le gayness
                                Turbo M42 Build Thread :Here
                                Ig:ryno_pzk
                                I like the tuna here.
                                Originally posted by lambo
