R3Vlimited/BBQ2U PRO3 build/Journal
  • samiam3356
    • Jul 2009
    • 1901
    Nice work so far especially on that sunroof.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • david2991
      • Nov 2011
      • 315
      Ditto on the sunroof that is superb work. One day.
      • KoKoSe7eN
        • 253
        how much were the new calipers?
        91' MtechII AW/SW BAR'd S52/SC
        • Jparkr
          HR Admin
          • Jan 2006
          • 3494
          Originally posted by FunfGan
          Awesome so far! also just gave me an idea for a cleaner looking sunroof delete... I assume that compound can be bought for noncommercial use?
          Yeah, I got mine from single source but any paint/bodyshop supplier can get it for you.
          If I remember right, I think the rears were $37 dollars with a $20 core and the fronts were $40 with a $15 core.
          1987 PRO-3 car /1990 325is (2.7i Concours)
          • Jparkr
            HR Admin
            • Jan 2006
            • 3494
            Front suspension
            reassembled and up on the lift
            before shot
            Front goodies
            Dirty
            Clean and freshly undercoated
            Cut for the camber plate
            Girlfriend filling down the sharp edges
            Strut assemblies installed
            Sway in, control arms in.
            AKG adjustable caster CAB
            Getting it done, my Dad looking at the progress
            Bearing and hub installed
            Brakes in, Sway hooked up
            Tie-rods in
            Fronts done.
            Rear suspension
            getting some of the parts ready
            Disassembling
            Subframe out
            Chassis before
            bye bye diff, it went to James' car
            Pulled apart subframe and pulled hubs from bearings
            Damn. Well one inner race stuck on is better than two.
            Pressure washed the subframe and tacked on the toe adjustment plates
            Tacked up the camber plates
            Welded, painted, and ground out camber plate
            Toe plates done.
            This was my work bench for welding and painting
            Trailing arms clean painted and ready for reassembly
            Re-enforced sway bar mount.
            Wheel bearing time
            Bearings in
            Hubs pressed back in
            Got the sway fitted in, then took it out to undercoat.
            Reid welding up the diff mounts to re-enforce them.
            Undercoating
            Diff mount toughened up
            Fitting the subframe, I had to see how much of the bushings to shave off. It need to be done to get to the nuts on the outside of the toe adjustment plates.
            Assembled and ready to go in.
            In, and sway hooked up.
            Shocks and springs installed
            Assembled, time to do the brakes
            Brakes! Hooray!
            Stance be damned! this car does real work!
            • Thrizzle
              • Aug 2011
              • 194
              So proper!
              • Court M3
                • Jan 2004
                • 6713
                Can't wait to see this complete!
                Continuous For Sale Thread
                323i s50
                • Lof8
                  • Oct 2006
                  • 2827
                  Looking nice! I would be concerned about cutting the strut towers. I guess you don't see it as a source of more flex/weakness?
                  S50'd
                  Originally posted by TDE30
                  What is this faggy shit I have happened upon?
                  I can always live in a M3. Can't M3 a house.
                  • Jparkr
                    HR Admin
                    • Jan 2006
                    • 3494
                    No, It may be a tad bit weaker when broke down on paper, but it is unnoticeable and completely safe. I have a sparco front strut bar to install as well.
                    • 2mAn
                      SeƱior Mod
                      • 20368
                      do you think you'll be running this year? so many PRO3 builds happening this year. i hope to be out on the track, but Im building a Club Rabbit car. It fits in my budget and i have a shit-ton of spare vw parts so it made more sense than a PRO3. hope to see the BBQ2U out there
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      -2006 Volkswagen Jetta TDI
                      Make R3V Great Again -2020
                      • ck_taft325is
                        • Sep 2007
                        • 6880
                        Parker... when can I come down and help out? I feel like I've missed far too much already!
                        Need a part? PM me.
                        • bmnut2002
                          • Nov 2009
                          • 198
                          Nice job Parker, looking great!
                          Kevin Doyle
                          KD Motorsports
                          KD.Motorsports@yahoo.com
                          9175 Willows Rd NE
                          Redmond, WA 98052
                          (425)556-9076
                          • dude8383
                            • Jan 2005
                            • 10387
                            Wow. That looks like a ton of fun man! That cage is beautiful!!
                            I've never really delved into the differences between PRO3 and SpecE30 but boy oh boy, seeing this I can definitely see that you guys can run nicer suspension setups.
                            • FunfGan
                              • Jan 2011
                              • 4958
                              Awesome, thanks for the info. Good luck!
                              Go here be happy!
                              Ratchet Garage e30 V8 build.
                              • jpichu
                                • 266
                                I like The Color of the cage Too
                                http://youtu.be/aOhYdZfY9QY
                                https://vimeo.com/40801938
