89 325i LS Swap (Rust Repair & Respray Underway)
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4504
    #136
    What did she make?
    • Pootis
      • 636
      #137
      Ran into some issues. Trying again this Wednesday. I will report back
      1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
      COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
      • Pootis
        • 636
        #138
        Dynomite Dyno is an absolute heartbreaker but here is a good comparison of the 4.8 numbers vs 6.0 numbers. Really healthy curve and on a dynojet it would make 387/387 or more. Really happy with the results and the car absolutely rips. Dyno Pull linked below
        Dyno:
        • mike.bmw
          • Dec 2015
          • 1777
          #139
          That sounds quite nice!
          • jstoll
            • Oct 2017
            • 64
            #140
            hey... do you remember what RPM your boost threshold was with the M20 and HX35 what I mean by that is at what RPM did boost come up... Im running a T3 T04E now and the boost threshold is 3200rpm... very useable but have a holset HE351CW with a 9cm housing .. I think most of the HX35 were 12cm accept maybe one year automatic which had a 9cm ...was yours 12 or 9cm on the turbine housing??
            that is a really nice build you have there BTW ... nice work..
            JAK
            • djjerme
              • 5082
              #141
              Ok Pootis - I have to ask - TF2?
              2016 Ford Flex
              • Pootis
                • 636
                #142
                JAK
                It came on late close to 4k I had an HX35 with the 12cm housing. I've never seen one with a 9cm housing but it would definitely help spool times. Might die off on the upper end though
                Ha no just a nickname I have had since I was a kid
                • 2mAn
                  Señior Mod
                  • 21024
                  #143
                  over 300whp is insane...
                  we need a burnout video once those tires are ready to be replaced
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • jstoll
                    • Oct 2017
                    • 64
                    #144
                    the car would show about 400whp on a dynojet...
                    I used do do tuning for a living ... different dyno brands show different numbers on the same setup...
                    JAK
                    • Pootis
                      • 636
                      #145
                      I have a set of wheels and tires in the garage I have specifically kept for that just need a good photographer
                      JAK
                      Yeah the shop I had it tuned at has a mobile dyno and this dyno and he said if we strapped it on the mobile dyno it would be at least 50 more hp and tq than this one.
                      • Pootis
                        • 636
                        #146
                        I need to take more photos when I am out and less just in my driveway.
                        • tyeler18
                          • Jul 2019
                          • 141
                          #147
                          Looks like you did the brakes the same way I was planning to. If you don't mind i'd like to pick your brain a bit on the changes you're making to the hydroboost setup since I'm in the process of getting mine ready and you have the same setup engine wise to me basically.
                          • Pootis
                            • 636
                            #148
                            Yeah send me a pm
                            • Pootis
                              • 636
                              #149
                              Couldn't pass up on the deal I got for a set of Borbet Type A's this weekend. I'm going to refinish them and get a new set of tires on them. The OZ Vega's aren't going anywhere though just want a different set to change the car up every once and a while. These came with flat caps as well
                              • Pootis
                                • 636
                                #150
                                Haven't driven the car in a while winter has really set in in KC but got it out last weekend to air it out and take a pic with the new daily. I am ready for Spring. I also keep going back and forth on whether I am going to tackle the rust issues myself or not.
