FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
  • e30m20TurbO7
    • 1203
    #181
    So I found out what was , wrong with my motor , and it has nothing to do with the compression , or the rings , I've got a few options , il show everyone what my plan is as soon as I got my car in a garage that's heated
    Originally posted by efficient
    so you ever figure out what was wrong with your motor?
    • AnimalE30
      • Aug 2009
      • 266
      #182
      Soooo what happened?
      • Cronopoulos
        • Jul 2011
        • 2187
        #183
        The suspense!
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • e30m20TurbO7
          • 1203
          #184
          So I finally found a place to rent out to store / work on my car for 125$ a month 2 miles from my house , it's on a persons property so there are no hour limitations ,
          I've got some major plans for her
          • e30m20TurbO7
            • 1203
            #185
            I decided to put a days worth of work in .
            I stayed focused and knew what I was doing for once in my life.
            • e30m20TurbO7
              • 1203
              #186
              Who likes m20 carnage!
              Problem knocking bearing was 5 and that's the first bearing I show
              rods 3 and 4 were spun
              Bearing 3 rod end cap
              Do you see what I see
              Tomorrow will be fun
              • F34R
                sLaughter
                • 12385
                #187
                I remember that engine block color, this is your second rebuild? 3rd time is always the charm.
                Post# 52 learn and do it right this time.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • e30rapidic
                  • 2167
                  #188
                  did your oil pump bolts work themselves loose?
                  '87 325ic, powered by S50.
                  • e30m20TurbO7
                    • 1203
                    #189
                    All my oil pump bolts were tight , it's cool tho
                    You're right 3rd time is the charm , I'm not even worried about it , I think I spun bearings due to tolerances not being there or possibly the part manufacturer sent me the wrong ones . I got a spare crank that il have checked out , some of my rods look a little scored . Keep on truckin
                    At least il make it to mfest this year
                    http://www.r3vlimited.com/board/show...=243359&page=2
                    • e30m20TurbO7
                      • 1203
                      #190
                      The last start up before tear down
                      Thought everyone might want to see
                      • e30m20TurbO7
                        • 1203
                        #191
                        Block got torn down , I took it to the car wash to degrease is with tire and engine cleaner then pressure washed the oil galleries and then took it back to the shop and put oil in all the cylinders to keep from Rusting
                        Another days worth of work
                        • Cronopoulos
                          • Jul 2011
                          • 2187
                          #192
                          Nice work man!
                          • kid325e
                            • Sep 2007
                            • 6421
                            #193
                            Are you running a B25 oil filter housing?
                            Check it out buddy! Loved the block color so much...
                            Sent from my LG-P999 using Tapatalk 2
                            clutchCTRL!
                            Move with a purpose.
                            - 1991 325iX 4dr/5spd
                            - 2000 323i AT
                            2016 Mazda CX3 Sport AWD
                            • kid325e
                              • Sep 2007
                              • 6421
                              #194
                              clutchCTRL!
                              - 2000 323i AT
                              • e30m20TurbO7
                                • 1203
                                #195
                                yea i am running one but i have the oil cooler lines capped off till i ethier buy new oil cooler hoses , or get the hoses crimped because they leak , block looks good man
                                Originally posted by kid325e
                                [ATTACH]65604[/ATTACH]
                                spare crank was dropped off at the machine shop .
                                My autohausaz bill is 274.00
                                my blunttech bill is 120.46
                                machine shop fees 35.00 for micro polish cleaning and measuring
                                summit o-ring tool 60.00
                                The list
                                connecting rod bolts 70.00
                                fuel filter 9.00
                                selector shaft seal 3.76
                                exhaust nuts 5.61
                                goetze headgasket 33.21
                                waterpump gasket 1.00
                                timing cover gasket 1.12
                                shift linkage clip 1.42
                                oil pan gasket 3.61
                                mahle oil filter 4.33
                                M/T shifter bushing 6.96
                                main bearing set 92.21
                                plastic spoiler nut 5.70
                                input saft seal 4.97
                                exhaust hanger 2.67
                                exhaust donut 1.56
                                manifold gasket 19.00
                                downpipe gasket 8.32
                                motor mount 8.31
                                cylinder head bolts 17.53
                                rear main seal 8.89
                                temp sensor 6.98
                                rod bearings 42.76
                                clutch pedal 1.85
                                brake pedal 2.96
                                assembly lube 6.08
                                bmw coolant 24.94
                                coolant drain plug 1.61
