FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
  • Cronopoulos
    • Jul 2011
    • 2187
    #211
    Looks great, keep the progress coming!
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • e30m20TurbO7
      • 1203
      #212
      No slobbering over the Oring
      Piston 1
      Piston 2
      Piston 3
      Piston 4
      Piston 5
      Piston 6
      Main cap 1
      Main cap 2
      Main cap 3
      Main cap 4. Too tight ?
      Main cap 5
      Main cap 6
      • e30m20TurbO7
        • 1203
        #213
        Anyone remember me having really low compression , 90psi in all the cylinders
        Well those of you saying its the rings , were correct I get my new rings in the mail tomorrow , heres some pics of the ring gap.
        Last time I didn't remove any of the rings because I was scared of breaking them, so I never checked the gap.
        So I borrowed a old worn out piston and I took a ring of that for reference
        This is the ring gap of the oil ring to this piston
        Here's a pic of my old ring gap , enjoy the laughs
        All of the rings were pretty much identical in gaps
        , so Goetze rings are being put on tomorrow , hopefully il have her built by Sunday or Monday .
        Some pics
        I resprayed the block
        I reused the old washer from the old sheet metal style oil pump drive gear , because no one would sell me the washer on here call me crazy I think the washer will be fine I made sure to torque her down nicely.
        New coolant plug
        Ported the intake to make it really smooth
        Smoother than it looks
        • efficient
          • Feb 2012
          • 3312
          #214
          looks good. cant wait to see your progress.
          • e30m20TurbO7
            • 1203
            #215
            I put the pistons in today , the end gap was 0.48mm
            I checked to see if all my valves were sealing by pouring some gas on all them , none of them leaked Looks like the machine shop did there job right , I also just got a tooth brush and cleaned the combustion chamber with the gas , worked really well
            Gas cleans well
            Was about to put the head on today, opened the brand new box of head bolts
            And there was 13 out of 14 can a guy get a break
            • Cronopoulos
              • Jul 2011
              • 2187
              #216
              Almost there!
              • efficient
                • Feb 2012
                • 3312
                #217
                why do your cylinders have rings on top of them?
                • whodwho
                  • Jun 2008
                  • 1547
                  #218
                  Originally posted by e30m20TurbO7
                  Looking good
                  The o-ring ends should meet at one of the head studs
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • mrbeef612
                    • Oct 2012
                    • 157
                    #219
                    Looks a bit dry... Do not be skimpy on the engine building grease....
                    • e30m20TurbO7
                      • 1203
                      #220
                      Just a pic update
                      • e30m20TurbO7
                        • 1203
                        #221
                        • e30m20TurbO7
                          • 1203
                          #222
                          selector shaft seal is being replaced. i replaced the output shaft seal , i also am waiting for two new rod bolts since i decided to do the 70degree torque angle by eye , then has second thoughts and ordered two new bolts , and called a buddy with a degree torque wrench , hes gonna bring it over this weekend, DO IT ONCE AND DO IT RIGHT, theres no point in rushing a engine build , because your just gonna have to do it over again if you cut corners
                          • mrbeef612
                            • Oct 2012
                            • 157
                            #223
                            Are you using any engine assembly lube? If the engine has problems starting and you have to turn it over a lot you will kill all of the bearings because it will not build oil pressure.. Just a FYI....
                            • JCarp90
                              • Feb 2011
                              • 1759
                              #224
                              Looks badass. Keep it coming.
                              • e30m20TurbO7
                                • 1203
                                #225
                                yes im using assembly lube , i use liqui moly assembly lube in the blue sqeeze bottle , its what bmw recommends
