My '73 Roundie Revival [BMW 2002]
  • CubbyChowder
    • Mar 2012
    • 1488
    #331
    Originally posted by IronFreak
    YES!! Progress!! Dude I love your car, your spirit and mindset. Keep up the great work. It's so cool to see others with ability and same passion I have for fabricating doing what they love!
    Thanks man! I'm happy you can understand where I'm coming from
    Originally posted by JCarp90
    So glad to see this build moving again and things working out for you.
    Keep up with the updates!!
    I am very glad to see progress happening as well, updates will be flowing in from here on out!
    Originally posted by mtlbloodshot
    ahh wow!! Im so happy for you man. Cant wait to see this done.Keep up the hard work and don't get discouraged!
    Thanks dude, things do get discouraging at times but that's all part of the process.
    Originally posted by dillon7
    This is by far my favorite build. You are building my dream, can't wait for more progress!
    I'm honored to hear that! Stay tuned, there is more to come
    --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
    --Golden Boy E30 Build Thread-- (sold)
    • serdar255
      • Feb 2013
      • 395
      #332
      Loving this thread!
      Nice progress good sir.
      image (10) by serdar.gurhan, on Flickr
      PM me for custom shift knobs and stickers!
      Originally posted by marshallnoise
      You ain't done working on a car unless you are bleeding.
      • AwakenNoMore
        • Dec 2010
        • 1291
        #333
        Those wheels give me a naughty feeling. This car is going to be insanely cool.
        1991 325i - "Scambles" The Daily Driven lightly modded.
        1988 Mazda RX-7 TII "Mako" The Free Dorito
        bacon by Jared Laabs, on Flickr
        • Zreberlcoe
          • 1555
          #334
          Dude your skill is remarkable. Damn this is cool!
          1991 325i Calypso Coupe
          Like Grandfather, Like Father, Like Son
          BMW
          • Addison325ix
            • Apr 2013
            • 110
            #335
            Fantastic job, keep up the good work
            • CubbyChowder
              • Mar 2012
              • 1488
              #336
              Thanks everyone, expect a big update within the next few days. Been putting in a lot of work!
              • Zreberlcoe
                • 1555
                #337
                Thank god! I'm excited!
                BMW
                • NickL
                  • 562
                  #338
                  This makes me so happy haha. Exact same process as the fronts on my E30. Awesome job dude.
                  1987 325is - S52
                  • CubbyChowder
                    • Mar 2012
                    • 1488
                    #339
                    Thanks dude :up:
                    Progress.
                    So I was in a bit of a dilemma about the rear fitment. In order to get it to sit where I wanted when aired out, I had to run a 20mm spacer. This meant I would have to run extended wheel studs as well. Extended studs and a pair of 20mm spacers would run me about $100 total. This got me thinking. The negative camber while aired out was pretty extreme, more than suits my taste. Instead of going that route, I decided it might be a better idea to kill two birds with one stone. I thought it would be a good idea to pull the rear subframe again and put that $100 towards weld-on camber adjustment tabs so I could add some positive camber back. This would theoretically eliminate my need for extended studs and spacers and bring some functionality back and give my tires some more life at the same time. Seemed like the better option, so that's exactly what I did.
                    So once my mind was set, I ordered the tabs and pulled the rear subframe again:
                    I notched out the original trailing arm mounting points in preparation for the new tabs:
                    Lined everything up and started welding:
                    As you can see with the new tabs welded in, the top half is not reinforced at all, so I thought it would be a good idea to box them in. To do so, I created 4 of these:
                    These filled the empty space, as shown in this picture. Notice that I purposely set the new camber tabs so that the lowest mounting point is about 1/4" higher than the original mounting point. I did this because it didn't seem like these camber tabs provide too much adjustment, so I wanted to make sure I could add enough positive camber to straighten things out:
                    Welded them up and then prepped/painted the whole rear subframe:
                    Once that was all done, I removed the bottom spring perch on the trailing arms by drilling out the spot welds with a spot weld cutter drill bit. This is where the bottom of the rear bags will mount:
                    And then ground everything smooth. You can see I drilled a little too far with the cutter on most of them. I've never done this before so it was a learning thing for me. I don't think it'll be an issue, I'll most likely reinforce that whole area anyways:
                    Got the whole rear subframe/trailing arm/differential assembly back together and ready to install (I temporarily bolted the spring perches back on so I could install the stock springs again because I need to get the '02 off the lift to work on a friends car this weekend):
                    Once everything was bolted up, I had the opportunity to see if all that work was worth it. To be honest, I thought it was going to make a bigger difference, but I am still happy with the end result. Here are a few pictures showing the differences between full negative camber (left) and full positive camber (right) at the aired out height:
                    As you can see, it's not a world of difference, but it definitely helps. I think I will still run a 5mm spacer to get the lip out a tiny bit more, and I won't have to run extended studs that way, so that's a plus! Hopefully my tires last a little longer this way as well. Keep in mind, these pictures are when the car is aired out, not at the height I will be driving.
                    With that squared away, I could focus on the fronts again. My replacement shock which I ordered from BagRiders arrived (ruined shock on left, new shock on right):
                    Was super nervous welding it the whole time but everything worked out fine:
                    Lastly, I welded on new tabs for the brake caliper line bracket to bolt to and then prepped/painted those. Super happy to see both fronts completed and painted up :)
                    So that's where I'm at now. I just ordered new brake rotors and calipers for the front, so those will get installed as soon as they show up. Once I'm done working on my friend's car and a "customer's" Jeep I will get at it again and get the brackets for rear bags fabricated and get those mounted up! Stay tuned!
                    • AwakenNoMore
                      • Dec 2010
                      • 1291
                      #340
                      Looking great!
                      • LJ851
                        • 7919
                        #341
                        Toe is what wears your tires quickly, camber mostly just makes the wear uneven. I would recommend you add toe adjusters to the subframe to help this. You could pull the pivot bolt out of that side of the trailing arm when aired out and move it back half an inch or so to see if you like the change visually before you purchase and weld.
                        Lorin
                        The M30 is God's engine.
                        • semaj4712
                          • Mar 2012
                          • 3069
                          #342
                          Looks great so far, couple questions for ya, where did you get those MK1 fenders from, cant seem to find the rears from RabbitParts.com, also I think in one of your first pages you talked about getting the rubber seals for the windows, where you buy those from.
                          Thanks
                          Also, how much space do you have on your wheels on the inside, I am trying to run 9.5s in the rear and your outside fitment is perfect, just curious about inside clearances
                          29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
                          72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
                          Gewerkschaft der Polizei Sticker/Clings For Sale $8
                          • knuklehead92
                            • Aug 2011
                            • 732
                            #343
                            Thanks
                            flares can be found here
                            Trust me it stock :yawn:
                            • semaj4712
                              • Mar 2012
                              • 3069
                              #344
                              Oh dope even cheaper than I expected, are you guys running large or small sizes?
                              • CubbyChowder
                                • Mar 2012
                                • 1488
                                #345
                                I don't think there actually are sizes, I wonder why it suggests that. Just buy four rear wheel arches, 2 driver's side and 2 passenger's side.
