My '73 Roundie Revival [BMW 2002]
  • CubbyChowder
    • Mar 2012
    • 1488
    #181
    Originally posted by lambo
    Easily my favorite build going on right now... The down-to-earth-ness, diy-ness, and attention to detail is superb!
    Thank you! That means a lot.
    --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
    --Golden Boy E30 Build Thread-- (sold)
    • JCarp90
      • Feb 2011
      • 1759
      #182
      This.
      • Bimmerguy91
        • Jul 2012
        • 982
        #183
        Awesome build thread! Keep at it!
        • CubbyChowder
          • Mar 2012
          • 1488
          #184
          Finally had a day off work so I went up to my dad's to get some work done. Ended up being cold and windy so body work was a no go. I decided to make some progress on retrofitting the VW crosshairs to the stock 2002 headlight buckets. The crosshairs were a bit bigger than the original sealed beam headlights, so I had to figure out a way to secure them. It was a bit tricky, but I managed to make it work.
          It looks a bit funky, but I made two little brackets which ended up working with the stock mounting location of the sealed beams:
          The third area was a little trickier, and I didn't really know what to do with it. I ended up figuring out a way to secure it with a U-shaped bolt thingy haha, super snug now though:
          Then I mocked it up. I decided to take pictures without the grille installed. My driver's side grille is totally messed up so it looked janky. I'll have to find a clean one, which I'm sure will be hard:
          • Link
            • May 2012
            • 834
            #185
            I read through your e30 build and thought that was very nice, and now this on top of it.. wow. Keep up the work man.
            View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
            • straightsixe30
              • Sep 2011
              • 275
              #186
              Couldn't agree with you more on the bbs wheels. They are common place but for good reason...If done properly the beauty is un-matched.
              • CubbyChowder
                • Mar 2012
                • 1488
                #187
                Alright so I know I already posted a few pictures of the crosshair retrofit but I figured since I had to do the passenger side today that I would just post a step-by-step process on how I did it. It's pretty pic-heavy so hang in there guys.
                First off, here is how the crosshair came out of the box:
                And here is the stock sealed beam headlight still attached to the bucket:
                I started off by taking the crosshairs apart from the mounting plate and adjuster screws:
                Here is the crosshair next to the headlight bucket, you'll notice that the headlight has three mounting tabs:
                Next, I cut the three mounting tabs off:
                Here is how the crosshair sits in the bucket, it's a bit bigger so it sticks out a bit and doesn't sit flush:
                I made these two brackets out of little metal pieces I found at my dad's (pictured under the brackets). These are for the two bottom mounting points:
                Here they are installed:
                The top mounting point was a bit different since I couldn't use a bracket like the bottom two. From cutting off the mounting tabs on the crosshair, there was still some metal left over, which I bent up and drilled a hole through:
                Then I cut a slit in the headlight bucket:
                And from there I straightened it out and drilled two holes:
                That way the tab from the crosshair would slide right into the slit I cut into the bucket:
                Then I shortened the tab a bit so it wouldn't poke out:
                And I zip tied it all together. I used a U-shape bolt thing on the last one but felt it was a bit overkill. A zip tie works perfectly fine in this case, and it's much more simple:
                And there we have it! Here are some mock up pics:
                After that, I decided to prep and primer the door jamb. So I spent a few hours grinding it down to clean bare metal:
                And laid down some primer before it got too cold out. Still wet in the pictures:
                And that's it for today! I still have sooooo much work ahead of me, I got a little overwhelmed today but I'm just taking it one step at a time. This car will be my pride and joy when it's complete.
                • JinormusJ
                  • 6887
                  #188
                  Free
                  King
                  Dope
                  That headlight retrofit is the bees knees
                  I already can't wait to see this thing done
                  • squidmaster
                    • Aug 2011
                    • 2666
                    #189
                    I never saw this thread how? Amazing work.
                    • CubbyChowder
                      • Mar 2012
                      • 1488
                      #190
                      Huge thanks to Will at BagRiders for hooking up the $100 discount!
                      • mtlbloodshot
                        • Jul 2011
                        • 761
                        #191
                        I like this
                        MY BUILD THREAD
                        http://www.r3vlimited.com/board/showthread.php?t=235231
                        INSTAGRAM : @luchcolaneri
                        • CubbyChowder
                          • Mar 2012
                          • 1488
                          #192
                          I'm a happy camper today :D
                          Air Lift 75561 Universtal Struts for the front, Air House 2 bags for the rear:
                          Currently saving for AccuAir E-Level, I am literally cutting costs on everything to make this happen. Once that is paid for, I can return back to a normal lifestyle haha.
                          • hfabricius
                            • 608
                            #193
                            "Bag Pictures"
                            I can't wait until I can get mine for the e30!
                            http://halden-fabricius.tumblr.com/
                            • SirWolfian
                              • Mar 2012
                              • 132
                              #194
                              Holy McTitties Batman, this thread is AWESOME
                              I Say... that is some awesome shit!
                              '86 325e- (parts car)
                              '89 325i- DD and project aka "Shirley"
                              Progress thread for Shirley
                              • chadthestampede
                                • Jul 2008
                                • 3601
                                #195
                                Ahhh wow this is amazing. Subscribed.
                                Originally posted by LJ851
                                Feedback
