Blunttech e12 LSx / t56 swap
  • blunttech
    • 12850
    #211
    That looks great Jake Did you buy a new parallel flow??
    Where are you going on vacation?? Im chuckling thinking about your pops driving this thing around ... Im sure he gets it though. He taught you everything right??
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • jakeb
      • 1909
      #212
      Yes that is a parallel flow...much better way to go for the R134a it will end up with.
      My wife and I are going to Traverse City...north west Michigan...known for cherries and lots of vinyards/wine and good eats.
      haha yeah my Dad gets it....most of the stuff he owns is stock tho so it will be a change if he drives it for a few days. He digs it tho..helps with all the projects I end up with.
      He did teach me a lot but even he says I "took it to the next level". But I grew up with him restoring cars. When I was 14 him and I restored my first car 75 Triumph Spitfire.
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • blunttech
        • 12850
        #213
        Awesome.. Enjoy all that time spent together ..
        I restored and worked on many cars with my dad as well before he passed away... great memories...
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • TrentW
          • 2815
          #214
          Great to hear it fire up finally. Congrats Jake.
          Steve, you're always welcome to stop by my house on the trip home.
          We could snuggle.
          • blunttech
            • 12850
            #215
            We could snuggle.
            If by "Snuggle" you mean me gently bouncing my bag off your chin I may head south. But the drive around the UP is really nice and zero traffic coming thru northern Wisc.. but there is always Vintagefest next year
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • F34R
              sLaughter
              • 12376
              #216
              lol, Steve wow
              Jake, where did you get that crimping tool?
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • jakeb
                • 1909
                #217
                ebay...but they sell that at all the AC places too.
                THis is what I have
                http://www.ebay.com/itm/Mastercool-7..._Tools&vxp=mtr
                • jakeb
                  • 1909
                  #218
                  Master cylinder is back on....getting those lines all hooked up was a BITCH. Mostly the ones on the bottom. Hard to push up and turn at the same time.
                  Either way it is hooked up......#5 coil will have to be relocated a little to clear the reservoir.
                  Upper radiator hose and efan. I looked for a single hose but couldn't find anything to do what I wanted/needed. So two hoses with a coupler will work. efan is a 16" puller...high and low speed controlled by the GM PCM.
                  As luck would have it the lower hose worked out being the left over piece/bend from the upper hose hooked to the radiator.
                  alternator/belt/etc are all on
                  • 325ix
                    • Aug 2009
                    • 7783
                    #219
                    Man, this thing is looking spiffy. I bet it will be a blast to drive.
                    • blunttech
                      • 12850
                      #220
                      so close .. Just front sway bar and alignment?? Man thats down to the wire... I cant see it being done before vacation unless youre a magician
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • jakeb
                        • 1909
                        #221
                        Yeah doesn't look like it will be done before we are gone for the weekend. I'll work on it more tomorrow afternoon and late night if I can get some time out there.
                        Just did did a little more.
                        Brackets for the sway bar. Need to box that back part in a little bit.
                        • jakeb
                          • 1909
                          #222
                          New sway bar mounts tacked on. Once I am happy with them it will get fully welded.
                          I was able to get the end link connected...it is at a slight angle. When I go to have it aligned I will look it over a bit better as the weight will be fully on the wheels and I can see how everything is sitting. End links are not fully tightened as well.
                          blurry pic but it is coming along....
                          • blunttech
                            • 12850
                            #223
                            Looks great Jake.... Did the bushing mount point change front to back?? or just drop down the height of the stock you used?? if it just dropped down Id think once its on the ground we may need longer links but it should line up fine. otherwise they may be preloaded??
                            sales@blunttech.com
                            www.blunttech.com
                            Like us on Facebook
                            • jakeb
                              • 1909
                              #224
                              The change is down and forward.
                              • blunttech
                                • 12850
                                #225
                                Cant be forward much can it??? Looks like youre nearly up against the strut rod washer
                                sales@blunttech.com
                                www.blunttech.com
                                Like us on Facebook
