Blunttech e12 LSx / t56 swap
  • ACHTUNG
    • May 2005
    • 2397
    #196
    I'm looking forward to item number 33
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
    • jakeb
      • 1909
      #197
      Plugged the PCM in about 30 minutes ago and powered it all up. PCM primed the fuel pump and is working. Did a read entire with HP tuners so I can pull out VATS and other unneeded things. VATS is like EWS in the BMW world.
      I did have one issue with how the unloader relay works...when I turned the key to on (not crank) the engine started cranking. I used a start relay because that is how GM does it and the fuse/relay panel I got came wired that way. I will just have to run a wire direct to the starter solenoid the way BMW wants it. Easy fix....
      e12 with an OBDII Port connected to a laptop....... :)
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • kid325e
        • Sep 2007
        • 6421
        #198
        That shot right there...
        That my friends is a Genuine Good Life. Kudos.
        clutchCTRL!
        Move with a purpose.
        - 1991 325iX 4dr/5spd
        - 2000 323i AT
        2016 Mazda CX3 Sport AWD
        • jakeb
          • 1909
          #199
          Intake setup is made...the filter might need to change to something a little smaller...not sure if the hood will close. But it will work for now.
          • Cronopoulos
            • Jul 2011
            • 2187
            #200
            Is that the ECU on the top of the shock tower? I had no idea it was that big ;)
            Project log -- DIRTY 30
            2.7i * Megasquirt tuned * E85 powered
            • jakeb
              • 1909
              #201
              Yeah that is the ECU...PCM in the GM world. It is pretty big. It will fit in the glove box tho.
              • Cronopoulos
                • Jul 2011
                • 2187
                #202
                Damn, keep up the great work. Love your updates with this!
                • blunttech
                  • 12850
                  #203
                  Looking like a real car jake. I think I have a line on switches Ill keep you posted Great work as always
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • jakeb
                    • 1909
                    #204
                    It's running!!
                    I can never remember how to flip the iphone to get the right orientation for youtube....
                    Either way here are a couple videos. I will get some better ones eventually.
                    The little light in the engine bay is a oil pressure light. You can hear it quiet down once the light goes off.
                    This is the first start
                    A little blip...you can hear a slightly choppy idle from the cam.
                    • F34R
                      sLaughter
                      • 12376
                      #205
                      Amazing job Jake, been one of my favorite builds this year. Thanks for the great pictures.
                      Cannot wait for the exhaust to go on and some clean notes! This will be really amazing to drive. Steve must be super excited!
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • blunttech
                        • 12850
                        #206
                        exhaust is actually on... Hard to tell in a closed garage with lots of valvetrain noise. Jake says the lifters pumped up and quieted down. He has a clip of the exhaust he says he will post later but he has family stuff hes trying to balance with completing this. If all goes well hes going to take the car on vacation next weekend to shake it down. Then Ill fly out and get it
                        sales@blunttech.com
                        www.blunttech.com
                        Like us on Facebook
                        • jakeb
                          • 1909
                          #207
                          Yeah for some reason it is hard to capture very good sound clips in my garage. Most of the sounds you hear are just from the engine...valve train and intake sound. Exhaust is pretty damn quiet.
                          • ACHTUNG
                            • May 2005
                            • 2397
                            #208
                            Right on. Solid work Jake.
                            • F34R
                              sLaughter
                              • 12376
                              #209
                              Man, I swore it was just so loud. I am sure everything will quiet down once you take her outside into the open. Congrats on the firing Jake, such an awesome job wiring and fabbing this monster. Looking forward to some burnouts on some junk tires!
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
                              • jakeb
                                • 1909
                                #210
                                thanks guys, glad it is running! After a little research it looks like the pushrods are a little short. So I have a set of 7.450 on order. The ones in it now are 7.400. That should add a bit more preload on the lifters and quiet down the valve train some.
                                Worked on the AC lines today.
                                These are the crimped low side to compressor (short line) and high side from compressor to condenser.
                                In the tool and pre crimp
                                post crimp
                                Entire crimping tool/setup
                                Heater hoses also done...AC lines feeding up to the drier (not connected yet) and the low side to the evap.
                                Bad picture...but where it goes up front..
                                Other side before it goes to the condenser.
                                Hooking to the condenser
