Blunttech e12 LSx / t56 swap
  • jakeb
    • 1909
    #181
    Took today to try and wrap it up....wiring is taking longer than I expected. But progress none the less.
    I laid the harness back out on the engine....now off the engine and repinned to the connectors. Looking like the PCM will reach into the glovebox.
    Rewrapping the harness
    Laying it back out on the engine
    Still more to clean up...wires can be tied into the e12 harness now..
    The extra fuse/relay box.
    Intake is coming together
    Now I wasn't expecting that filter was going to be that big....
    Both of these filters have a 3.5" inlet.... The one on the right really isn't that small either.
    The filter I ordered is just about the same size as my head.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • F34R
      sLaughter
      • 12385
      #182
      Wish I was awesome at wiring, looks great! love the mug shot...thinking my new Avatar?
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • jakeb
        • 1909
        #183
        yeah maybe the new avatar...or maybe this one.
        • F34R
          sLaughter
          • 12385
          #184
          I believe I enjoyed the second one best, it is a classic bad ass face of pure wiring madness.
          Current cars:
          ~ '87 535
          ~ '06 X5 4.8is
          • jakeb
            • 1909
            #185
            haha...and you made it your avatar. NICE
            • blunttech
              • 12850
              #186
              Love it jake. Gotta get to a computer
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • ACHTUNG
                • May 2005
                • 2397
                #187
                Fisting the intake. You filty man.
                1989 US E30 Cammed S52
                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                • jakeb
                  • 1909
                  #188
                  haha
                  • F34R
                    sLaughter
                    • 12385
                    #189
                    Fisting lol, my new favorite thread on r3v! I would like to request a new funny Jake picture each awesome update. Weird as fuck, something Steve would be proud of.
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • jakeb
                      • 1909
                      #190
                      More wiring....engine side is done and all wrapped up for the most part. Still need to connect the grounds. Next up I can tie the LSx harness into the BMW harness. The e12 has some weird wiring so I am trying to track down where the fuel pump feeds from.
                      Some pictures....
                      Made the hole bigger going into the car
                      PCM connectors reach without extending wires!! very good
                      You can also see the wires separated coming from the extra fuse box.
                      You can't really see but where the wires turn towards the inside of the car I make some little marks with a marker so I can keep things lined up.
                      Then just like a cooking show...20 minutes in the oven and we are done
                      OBDII Port and other wires that will go into the cabin, CEL, VSS signal for speedo, power/ground for speedo, and one extra power line. (wideband for tuning if needed)
                      Wires over at the drivers side where they will tie into the fuse box. coolant temp, oil psi, tach, fuel pump, 12v switched, start signal
                      Just another angle showing the routing.
                      • F34R
                        sLaughter
                        • 12385
                        #191
                        Awesome Jake, I owe you a brew if we ever cross paths. My top three favorite builds on here.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • jakeb
                          • 1909
                          #192
                          thanks man! Maybe we will meet up at a show one of these days. I am a fan of IPAs.
                          • jakeb
                            • 1909
                            #193
                            Little bit by little bit....
                            Wires going to the crank sensor, starter solenoid, and gauge temp sensor. Wraped in heat tape as they are all pretty close to the exhaust. That is how GM does it as well so...
                            New harness tied into the e12 fuse box. These wires will get wrapped.
                            AC pressure fitting that needs to be brazed together
                            A couple other things done but no pictures...or really pictures required.
                            Negative cable to block/battery
                            fuel line connected
                            • blunttech
                              • 12850
                              #194
                              wow really close now Cant wait to see you driving this thing around and hear it
                              sales@blunttech.com
                              www.blunttech.com
                              Like us on Facebook
                              • jakeb
                                • 1909
                                #195
                                If anyone is interested...here is the to do list. I love google apps/docs/etc
