Blunttech e12 LSx / t56 swap
  • franky2fingaz
    • Aug 2012
    • 117
    #91
    We spoke, and I read your thread on 1st5s but this a good site (for my 80 E21) I never knew existed, which I won't build 'till I get my E12 running... keep us posted and like I said you need help (but you look almost done) with that swap let me know, just supply da bear.... cheers
    • jakeb
      • 1909
      #92
      I was waiting on the driveshaft and then was out of town for a long weekend. Got back at the car today...
      Driveshaft in, clears everywhere except at one spot on the subframe. Broke out the plasma and was able to open it up just enough.
      You can sorta see where I had to clearance the subframe.
      Transmission mount is made..well tacked up and holding at least. Still have to add a little gusset on the passenger side and clean it all up.
      Started on the exhaust...it is a tricky task getting around everything from the drivers side back to the passenger side. I had to order one more bend and a few band clamps...nothing else will really fit.
      From the top
      It's coming along....the exhaust is more than likely one of the more time consuming things. Just because there are so many things to get around. Hoping to have the bend and clamps tomorrow and then thursday I can finish the exhaust.
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • jakeb
        • 1909
        #93
        Also picked this up last week for my wife...
        • efficient
          • Feb 2012
          • 3312
          #94
          Cool mini
          • blunttech
            • 12850
            #95
            You do nice work Jake... I cant wait to terrorize the neighborhood with this.
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • F34R
              sLaughter
              • 12385
              #96
              1+
              and sexy mini, please post up more pics when you get a chance.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • ACHTUNG
                • May 2005
                • 2397
                #97
                what diameter tubing are you using for the exhaust?
                1989 US E30 Cammed S52
                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                • jakeb
                  • 1909
                  #98
                  2.25" and then it will go into a spintech with a dual in and single 3" out through a magnaflow
                  • TrentW
                    • 2815
                    #99
                    Nice work indeed.
                    Eager to hear the exhaust note on this.
                    • blunttech
                      • 12850
                      #100
                      Originally posted by TrentW
                      Nice work indeed.
                      Here is the same 6.0L with the same cam I bought and same LS6 intake. This GTO has headers which I wont have but otherwise the same I dont know how to embed lol
                      edit Thats a 5.7L but same cam Ill have a 6.0L
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • TrentW
                        • 2815
                        #101
                        Oh that's rich. With headers it wouldn't be as stealth. Stock manifolds should be just right I'm thinking!
                        • jakeb
                          • 1909
                          #102
                          • jakeb
                            • 1909
                            #103
                            More progress on the exhaust... Two 2.25" pipes coming from the passenger side is way way tight. But there is 1/4" or so clearance at any given point.
                            Passenger side how they snake around...
                            I really liked this joint so I had to take a picture. I make all my cuts with a sawzall. Now this was an angle cut on one side and straight on the other. It was the first cut and I normally just mark one side and go for it.
                            Same pipe..
                            There will be another hanger up in the front...but it is all tacked together
                            Still need to extend the tail pipe out. It's going to be a straight 4" exit.
                            Cam showed up today as well!
                            • blunttech
                              • 12850
                              #104
                              Nice work Jake Looks great .. Did the cam come with all the pushrods/dual springs etc?
                              Any word on the intake?
                              sales@blunttech.com
                              www.blunttech.com
                              Like us on Facebook
                              • jakeb
                                • 1909
                                #105
                                yup, cam was a kit, new PAC beehive springs, and upgraded pushrods
                                Intake is in route
