Blunttech e12 LSx / t56 swap
    • 37832
    #106
    Nice work on the pipes!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • jakeb
      • 1909
      #107
      Added another mount up front and a couple braces between the pipes to keep things where they need to be.
      Found a 3" to 4" adapter (had to go to the diesel place)
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • TrentW
        • 2815
        #108
        Pretty damned amazed that you can achieve those cuts with a freakin' sawzall.
        • blunttech
          • 12850
          #109
          The tip, Although its a poseur tip, really fills out the cutout in the valance and makes it look much better i think. Thanks Jake for putting up with all my little requests
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • jaywood
            • Jul 2010
            • 4528
            #110
            Very impressed by the sawzall work.
            When I did my exhaust I used a chop saw. So easy to get straight/angled cuts!
            • F34R
              sLaughter
              • 12376
              #111
              Why did you not go with a round muffler? So weird looking...
              But those cuts are so clean! nice job, I am about to do mine once the 409 3" gets in.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • 325ix
                • Aug 2009
                • 7783
                #112
                Wont the exhaust going right by the radiator like that cause the car to run hot?
                • blunttech
                  • 12850
                  #113
                  Theres no room between the tank and spare well for anything. Once the muffler is painted it will look fine. Besides You can tell im not real concerned with looks by the rest of the car
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • jakeb
                    • 1909
                    #114
                    The exhaust is pretty far away from the radiator to cause it to heat up at all......
                    Yeah the e12 and e28 with the center exit don't have much room for a muffler of any size. Hence the reason for a oval flipped. The muffler in the middle is a spintech...that's how they are.
                    I actually have an abrasive chop saw too but it is loud, stinky, messy, and some of these end up being compound cuts and the chop saw is a pita to do them. Also the sawall is way faster and doesn't get hot like the chop saw. I really don't use my chop saw very much...I have a horizontal band saw and that thing is great!! Maybe one of these days I'll get a cold cut saw but....it's not very high up on the list.
                    • jakeb
                      • 1909
                      #115
                      Here is how the BMW master cylinder will bolt up to the GM hydro boost...
                      From top to bottom....BMW master cylinder, plate to bolt to MC, adapter pin, short piece of pipe, plate to bolt to hydro boost, hydro booster, plate to bolt to firewall.
                      Plate to bolt to firewall...this one is centered but the one currently on the hydro boost is offset some.
                      Pin to go inside the MC plunger....nice to have friends with CNC lathes.
                      All stacked up...plates will be welded to the pipe.
                      I am using as many of the truck accessories and have to move some things around. There will be a bracket that bolts off the head and two spots on the water pump to hold the alternator. Also need to make a new bracket for the tensioner.
                      Debating adding another idler to allow a bit more belt wrap on the crank pulley. Leaning towards using the idler rather than not.
                      with...
                      without
                      • jakeb
                        • 1909
                        #116
                        A bit more progress today....the list is getting shorter.
                        ST Front sway bar in
                        Blunttech SS brake lines in
                        Suspension all tightened up
                        255lph fuel pump is in
                        TSP 224R cam, pac springs, and upgraded push rods installed. This was the first time I did this so it was a bit of a learning process and went a bit slow. By the last set of springs things were going quicker.
                        I didn't take many pictures through all of this as it isn't that exciting really...
                        parts laid all out
                        Old springs...
                        New springs...really doesn't look very different
                        Taking up the entire garage today....wife has to park outside. I really need more space!
                        • blunttech
                          • 12850
                          #117
                          Engine looks clean Jake You should really tell your tale of 3 motors.
                          Anyone else would have stuck the first one in and I thank you for that
                          sales@blunttech.com
                          www.blunttech.com
                          Like us on Facebook
                          • jakeb
                            • 1909
                            #118
                            The tale is.... The engine that was in the car was a 4.8L I had that I was using for mock up.
                            Picked up an LQ4 from a local yard from an 05. Looked really clean on the outside...start getting into it and there was dirt in one of the intake ports.
                            It went back...got another 04. Got the valve covers off and it is BLACK as can be inside. Do a compression test because of how bad it looked and come up with one cylinder low. It also had a fair amount of oil in a few of the exhaust ports.
                            Pics of that engine. Also if you notice 4 of the springs have been replaced for some reason....
                            Third engine that is here now had to be brought from a different yard to the one I got the other engines. Before they pulled it they ran it for 20 minutes. Oil is nice and clean. All the ports are dry...things look good.
                            So sort of a pain to go back and forth a bunch of times but all worth it to have a good engine.
                            • jakeb
                              • 1909
                              #119
                              Just a small update...
                              Fixed the hole in the firewall. Blunt wanted functional over looking good. It's nothing fancy but it will stop it from rusting more and fill the hole.
                              You can see the hole in the firewall here....
                              Some paint just to cover the bare metal...back side also was painted. This will all get covered up anyway with new insulation.
                              Relocating the alternator to make room....
                              Made a bracket, love my new plasma cutter. This will get drawn into cad and cut on a water jet for the final version.
                              Also mounts to the head. This may or may not stay.... There will also be spacers between the water pump and new bracket.
                              I'm not sure which idler I like better yet. I have another one coming to try too. Plate will be drilled and tapped for the idler pulley.
                              • blunttech
                                • 12850
                                #120
                                Nice work Jake I bet its fun trying to source the correct belt for that creation huh?
                                sales@blunttech.com
                                www.blunttech.com
                                Like us on Facebook
