Been ordering parts and working on the suspension. I need the driveshaft to finish the trans mount and then I can make the exhaust...and move ahead with things.
Front suspension is all apart..springs should be here tomorrow so I can get all that put back together. No pics really...pretty boring stuff to see there.
Dropped the rear subframe....a lift really makes it a quick and easy job.
Camber adjusters installed
Subframe ready to go back in...new trailing arm bushings, subframe bushings, ST sway bar, diff mount, and the adjustable camber.
Also got the filter/regulator in place. Will swap out the intank pump tomorrow more than likely.
