the Aluminum Monster. a 318 with a special 24v
  • wazzu70
    • Jan 2005
    • 1143
    #136
    On some of the exhaust hangars like that I put a ziptie around the outside to help keep them from stretching/breaking. The rubber still insulates vibrations, and the ziptie helps distribute the load.
    -Nick
    M42 on VEMS
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #137
      If you have constant hanger failure it makes me think there's something wrong; they should last for 100k miles. If you were running too rich or too lean, it would cause your exhaust temps to skyrocket and could melt the rubber hangers. I had it happen to me once when my O2 sensor died.
      • 2mAn
        Señior Mod
        • 20178
        #138
        If these ones fail then I will be concerned, but the ones that lasted 100+ miles were some cheap ones that didnt really fit great. I figured they were an improvement over the coat hangers. I was wrong.
        I will throw a ziptie around these ones though just to help them last
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • 2mAn
          Señior Mod
          • 20178
          #139
          went and met up with a guy parting out an E30 and was planning on getting the windshield to replace my cracked one, but sadly that one cracked too!
          Good news was that there were a few little parts that I needed to help tidy things up. small victories matter.
          My car, originally being a M10 318 had the battery up front and once it was moved to the back was missing the battery junction box, or whatever its called. Now the cable isnt hanging out in mid air, its tucked nicely up against the firewall and soon will be covered with M3 wiring harness cover things... someday in the future...
          I also bought a miata battery and will be addressing that soon. Basically it will be mounted just like all the other E30s that have their batteries in the trunk, though being that this one never had the cutout for a normal battery, the miata is a perfect fit, and shaves a few lbs from a normal battery.
          edit: Anyone have a tip on how to get that rubber insulator grommet thing in besides shear force? Its pretty big as is, but it tapers down where it actually goes around the hole on the firewall. I gave it a few quick attempts yesterday but I started working late and called it a day.
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • Red46
            • 1151
            #140
            Lots of lube ;)
            • 2mAn
              Señior Mod
              • 20178
              #141
              Originally posted by Red46
              Lots of lube ;)
              you'd think with how much lube Ive needed with this car, I would have a dispenser in the glovebox.
              So, the next step in the "I swear Mom its a good car," this brings us to the brakes. I used an iX booster and master with my swap and I love the brakes. Total OEM feel, nothing funny. well, there is that one thing though. The reservoir on the master and the VAC intake boot wanted to somewhat occupy the same space. Didnt seem like a big deal, I already had the 2002 reservoir, new blue BMW cloth hose and the little nipples. The FAQ sections never seemed to mention that the nipples needed a tighter hole (dont we all need a tighter hole?). So, as most of my projects go, the parts collected dust, I had a plan, I just didnt have time. Andrew over at Ireland Engineering had the right part, but I hadnt had a chance to get out there. Long story short, I finally got the parts I needed to finish the job.
              This isnt good...
              mmmm tight holes, next to a loose and abused one
              and then, as usual I hit a wall. Not literally though. I bought a fancy power bleeder about 3, maybe 4 years ago and used it once. Cleaned the dust off of it, and then... saw that the pump was broken. Hopefully I can get just the pump replaced otherwise this is all garbage.
              Then the next hurdle was the nipples. (this update is DIRTY!!) The nipples on the brake calipers are 7mm in size. My flare wrench set I bought only goes down to 8 and my box ends go from 8 -> 6.
              Luckily the brakes had been flushed within the last two months so they arent horrible, but obviously Id like to fix this ASAP. I am planning on tracking the car in about two weeks, then driving it up to Washington, driving it on the Maryhill Loops road, spending a week in Seattle for a pair of weddings , then driving it back down. Im sure I will need solid brakes at least one time in this next month.
              and the adventure continues....
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              • wazzu70
                • Jan 2005
                • 1143
                #142
                What is the remote reserivor from? Looks clean and gives better access to that area.
                -Nick
                M42 on VEMS
                • 2mAn
                  Señior Mod
                  • 20178
                  #143
                  Here are the part #s to get the 2002 remote resevoir setup
                  (1)- 21521163714 = Blue Cloth Hose
                  (1)- 34321112388 = 2002 Brake Fluid Resevoir
                  (2)- 34321102282 = Angula Pipe
                  total was $65 + shipping
                  I dont have a part # for the rubber pieces though as Andrew from Ireland Engineering got them for me
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    #144
                    That looks like a very clean setup that could come in very handy for V8 swappers. Thanks for the info!
                    Can you ask about the rubber thing? (Did you get an invoice or receipt that has it?)
                    • SkiFree
                      • Jun 2011
                      • 2766
                      #145
                      It was good to meet you on Saturday! The grommet part number is 34 31 1 121 911.
                      ADAMS Autosport
                      • 2mAn
                        Señior Mod
                        • 20178
                        #146
                        Thanks for the part# Andrew! It was also really nice meeting you the other day. I will be back up to the store one of these days as I need a front swaybar repair kit, BOTH tabs are broken
                        In other news, I registered for the El Toro Auto-X on the 19th instead of the track day. Its going to be an expensive few months so I figured I could spend money on other things that need to happen instead of having a fun track day and neglecting those other things.
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        • 2mAn
                          Señior Mod
                          • 20178
                          #147
                          allrighty...
                          so one of the next things I needed to do in preparation for abusing the car is fixing the things I think are broken.
                          first, go spend money on parts that should fix whats broken. trip to Ireland Engineering on tuesday to aquire parts.check.
                          swaybar_repair1 by 2mAn
                          inspect old parts. looks broken to me
                          swaybar_repair2 by 2mAn
                          swaybar_repair3 by 2mAn
                          and install new parts
                          swaybar_repair4 by 2mAn
                          swaybar_repair5 by 2mAn
                          I think I did it right It certainly feels better. I also cleaned the bar, so thats some weight savings ;D
                          Oh and the G260 appears to be leaking. one step forward... two steps back
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          • digger
                            • Nov 2005
                            • 5945
                            #148
                            been a while since i did my fronts but the thicker part looks like its on wrong? there is a step in the subframe that the thicker part of the plate mates to the left bolt as viewed in the pic
                            • LJ851
                              • 7918
                              #149
                              I agree with digger. Try not to be too in awe of my photo altering skillz. The steps mate together.
                              Lorin
                              The M30 is God's engine.
                              • Farbin Kaiber
                                Lil' Puppet
                                • 29502
                                #150
                                I know it's a while back now, but flex couplings in your exhaust, do you have at least one?
