the Aluminum Monster. a 318 with a special 24v
  • iansane
    • 1342
    #286
    Are you jumpstarting it off of the battery or the junction block underhood?
    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
    • 2mAn
      Señior Mod
      • 20176
      #287
      Originally posted by varg
      Sounds like it's time to pull fuses and use a multimeter across their connectors to check for current draw.
      My tools are at my garage, ~6 miles away
      Originally posted by pandaboo911
      adjust your trunk hinge so the trunk light turns off, and loctite it.
      My car is missing the clicker thing, so I just pulled the bulbs
      Originally posted by rzerob
      If your battery is fully charged then maybe something intermittent like a failing fuel pump? Was the car dead when you went to start it and wouldn't crank or it just would not start?
      It just wont start, doesnt turn over or anything... Im 99.99% sure its related to the charging system
      Ive never tried using the junction box under the hood, should I be?
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • DREWHALL
        • Feb 2006
        • 1207
        #288
        Never really made a difference for me. If anything going straight to the battery works better, and that's on E36-F10 anything between. When it doesn't start, does nothing come on at all? Or do you get cluster and all that jazz?
        • 2mAn
          Señior Mod
          • 20176
          #289
          Im certain theres a drain somewhere. I trickle charged the battery OFF the car and it fired up right away today, previously I was leaving the charger on the battery while it was directly on the car.
          I will let you know what I find to be the culprit. My guess is Stereo #1, the trunk light #2 and then ???
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • 2mAn
            Señior Mod
            • 20176
            #290
            So there was a big drop in mA draw when I pulled fuse #21... Im thinking when I began the process of adding the second trunk light I created a draw on the battery.
            edit: If the trunk light bulb is already pulled, then it has to be something else!!
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • Rdreas
              • Aug 2013
              • 164
              #291
              Draws are the worst!!! I have one from my interior, I believe it's fuse 6. Now my multimeter fuse blew so I can't trace it. Electrical problems suck! Still haven't figured out why my car cuts off randomly but then starts right up..
              • sam_
                • May 2014
                • 630
                #292
                ahh the elusive current draw
                1991 325i
                flickr
                @sambhaskins
                • 2mAn
                  Señior Mod
                  • 20176
                  #293
                  Just popped the #21 fuse and popped the replacement one....
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • MyE30
                    • Sep 2013
                    • 326
                    #294
                    Hope you figure out your draw issue. I'm sure you already have this info but just in case:
                    21 - 7.5 - Glovebox light
                    Flashlight
                    Ignition Key/Seat Belt warning
                    Interior Lights
                    Radio Memory
                    Trunk Light
                    Active Check Control
                    Service Interval Indicator
                    OBC
                    Fuel delivery
                    Tachometer/Fuel Economy Gauge
                    Digital Clock
                    Multi Function Clock
                    • 2mAn
                      Señior Mod
                      • 20176
                      #295
                      Flashlight
                      Interior Lights
                      Radio Memory
                      Trunk Light
                      Fuel delivery
                      Digital Clock
                      Yup, I read that in the Bentley. Just not sure where to start with this. Obviously I will need to check each item, but Im not sure what I need to check to confirm whether or not there is a draw from the Items.
                      I trimmed the list to match the options my car has. Slightly less BS to check.
                      Im trying to think what recently has been messed with to suddenly cause the fuse to pop. The only thing Ive messed with lately has been the trunk light. Over the weekend, I got my hands on the trigger which will illuminate the trunk light, but I still left the bulbs out after I installed it.
                      My car being a 84 318 doesnt have the check panel or an OBC, just had a digital clock which is now the analog clock.
                      I also dont have or know whats going on with the glovebox stuff. Ive never had the flashlight connection or a light in there.
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • 2mAn
                        Señior Mod
                        • 20176
                        #296
                        So... I've had some frustrating days with no luck in tracking down the draw and decided to do something different... I'll let the pics do the talking.
                        Also did this...
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        • glnr13
                          • 1334
                          #297
                          looks hot!
                          • yungmike
                            • Jan 2014
                            • 281
                            #298
                            +1 but looks like you should of hit mirror while you're at it too. :razz:
                            And which paint did you use too btw?
                            • 2mAn
                              Señior Mod
                              • 20176
                              #299
                              Originally posted by glnr13
                              looks hot!
                              etch primer and semi gloss rustoleum...
                              The mirror and the plastics are going to get the boiled linseed treatment. Paint adds weight and weight is the enemy. Anywhere I can avoid painting stuff, I will.
                              I will probably eliminate the OEM mirrors for some carbon DTM ones in the future.... around the same time I get a carbon fiber hood! :rofl:
                              Simon
                              Current Cars:
                              -1966 Lotus Elan
                              -1986 German Car
                              • MyE30
                                • Sep 2013
                                • 326
                                #300
                                Lol at this; not at you, just at the amount of $$$ it would cost.
