the Aluminum Monster. a 318 with a special 24v
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #436
    They do as far as I know. There are 3
    EDIT: oops, I could've sworn they were doing all three... just saw it's only the black/yellow
    Shadetree30
    • e30polak
      • 6136
      #437
      Originally posted by 2mAn
      Prior to that I will have my appt with the BAR referee! November 25th is the big day. Im excited to see if all this BS will allow me to finally get CA plates. Ive been itching to get my custom plates
      You'll want a different intake for the BAR inspection.
      INSTAGRAM: @UNDR8D_EMPIRE
      • JinormusJ
        • 6887
        #438
        Hey there sexy
        Nice car
        • 2mAn
          Señior Mod
          • 20973
          #439
          yea, pretty lame, but thats fine
          I've heard many different opinions on this and ideally I would have an airbox, but Im not shelling out $$$ for a castros box, my friend who was going to give me an E34 one has repeatedly flaked on me (in addition to the M3 firewall piece I bought off him), the M20 airbox didnt work, so Im at a crossroads...
          edit: on second though, if they arent that expensive a Castros Box would be an option I would take since i know the BAR has been cool with those boxes
          Hey there sexy
          Nice car
          hai ;D
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • 2mAn
            Señior Mod
            • 20973
            #440
            Soooo... Here we are. Last piece to the puzzle. The check engine light. Running two wires. I've already pulled the gray wire apart from the rest of the x20 mess so the now I just need to run that wire into the cabin, and hook it up to a light. Then the other wire needs to get a switched 12v source. What's the worst that could happen?
            Well, I ran the grey wire into the cabin. *check* Hooked up the wire to an extra light. *check* Now to find a switched 12v source. Figured the easiest place would be from the stereo. Tapped into that. *check* Got that wired up and now.... The light stays on the whole time the car is on. So I guess I have about 3 weeks to figure out why its on ... Joy
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • kronus
              • Apr 2008
              • 13032
              #441
              stomp test
              cars beep boop
              • 2mAn
                Señior Mod
                • 20973
                #442
                yup, thats what today will be. I finished last night and didnt want to deal with it. Im off work at 2pm on Fridays so hopefully the stomp test will actually work and give me some feedback
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • kronus
                  • Apr 2008
                  • 13032
                  #443
                  let's just hope it's not an unsolvable O2 sensor code
                  cars beep boop
                  • 2mAn
                    Señior Mod
                    • 20973
                    #444
                    yea this is definitely the biggest thing I hate about OBD1. My o2 sensor is brand new, so that would be an annoying place to start.
                    The thing that really drives me crazy with this is that the car runs perfect, so why do I need to check my engine! :(
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • pandaboo911
                      • 2070
                      #445
                      if you get 1234 you can ignore it, its for the speedometer signal. It'll throw 1234 even if you hooked up VSS correctly but won't trip the light.
                      Any code like MAF or O2 will be stored until you clear the codes so it could be from a while ago. You can clear them by cycling through all the codes and holding down the pedal for 10 seconds
                      • 2mAn
                        Señior Mod
                        • 20973
                        #446
                        Oh really??? Should I disconnect the battery for ~20 minutes to clean the memory out? Actually, explain this pedal clearing move
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • pandaboo911
                          • 2070
                          #447
                          check the codes first, then clear them and see if they come back. Some codes usually take about 15-20 minutes of driving in closed loop to trigger again.
                          I get 1234 every time I clear but I'm assuming that's because the ECU is not getting the signal it's expecting. It'll still work but throw a code for incorrect signal.
                          The ODB1 codes are so vague they're almost useless. Mine routinely throws codes for MAF and O2 sensor, but there's nothing wrong with either. it'll throw O2, MAF, or mixture for a vacuum leak.
                          • 2mAn
                            Señior Mod
                            • 20973
                            #448
                            Im just worried that with a CEL the BAR will tell me to GTFO
                            exactly how I feel. Id love to have kept the OBD2 brain, but I definitely dont want to try and BAR the car as an OBD2
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • pandaboo911
                              • 2070
                              #449
                              Yeah a CEL will for sure fail you at BAR. If you ever decide to say fuck BAR and liberate yourself from the SMOG nazis I can point you in the right direction.
                              • 2mAn
                                Señior Mod
                                • 20973
                                #450
                                Well, this stomp test won't work from inside the car. Im going to try manually doing it from the throttle body after I get some food. I'm hungry....my pedal stomping is getting more violent
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
