TR-42 build. Non e30 content. Subaru powered.
  • gotaloveRWD
    • Jul 2011
    • 708
    #301
    Almost two weeks and no update! I need more, your so close to being finished!
    IG- nv_e30
    • jaywood
      • Jul 2010
      • 4528
      #302
      Originally posted by anabolice30
      Shit OP. All I gotta say is this is awesome.
      Thanks!
      It's getting there man! We made a to-do-list. There's still quite a bunch but nothing too big.
      We made a shield for the firewalls to cover the ECU and the other misc wiring components, ie immobilizer.
      Reverse light mounted underneath the trans
      Cleaning up the wiring up front. Most of it is hidden in the "dash"
      I have a few more videos but nothing too exciting. We've been driving it and figuring out all of the coolant problems. The aftermarket (read - cheaper) thermostat we put in was bad so we had to pull it out and put a new OEM one in. The filler neck on the upper expansion tank has a leak so we are trying to solve that. We filled the air/water IC with water and wired up the pump w/ a switch. It works very well. The pump is almost silent.
      • DER E30
        • Sep 2013
        • 2347
        #303
        Love the beads in those panels! That reverse light looks trick! :up:
        -Christian
        • jaywood
          • Jul 2010
          • 4528
          #304
          Thanks man, that bead roller works surprisingly well! It's a lot easier having 2 people work it, one to turn the handle and the other to feed/guide the sheet.
          • JCarp90
            • Feb 2011
            • 1759
            #305
            Every time I look at this it gets cooler and cooler. Awesome work.
            • jaywood
              • Jul 2010
              • 4528
              #306
              Reverse light mounted and wired up. It's pretty bright, the pic doesn't show that however.
              We made the shields for both sides (immobilizer side and ECU side)
              And also a shield for the intake/filter.
              Wired up the boost control solenoid valve. It uses an EV-1 plug so I had to snip off the old plug and wire up this one.
              We also wired up the cluster. RPM works along with most of the other functions. We are working on getting an accurate speedo.
              • SamE30e
                • Sep 2007
                • 4319
                #307
                This is a wicked build.
                I'm curious. You mentioned a EJ205 before but it has AVCS. Is it a V8 EJ207 (The immobilizer would make it a v8 not a v7) or is it a USDM EJ257?
                Those Borg Warner turbos are pretty potent. I'm guessing you guys are shooting for around around 350whp?
                I can't wait to see some videos of this thing moving.
                1985 325e 2.8 Turbo VEMS
                • jaywood
                  • Jul 2010
                  • 4528
                  #308
                  We have two engines. The one in the car is an EJ255 out of a forester.
                  Thanks! And yes that's around what we want.
                  Look a few posts up. I posted a short running video :)
                  • SamE30e
                    • Sep 2007
                    • 4319
                    #309
                    Nice,
                    I meant MOVING... like fast lol.
                    • jaywood
                      • Jul 2010
                      • 4528
                      #310
                      Nice,
                      Lol, so do we. Can't wait to have it tuned! Just a few more bugs to sort out. We only get like 8 hours a week to work on it so progress moves somewhat slow.
                      • squidmaster
                        • Aug 2011
                        • 2666
                        #311
                        more details about that gauge (almost) cluster.... for a... friend... 8-)
                        come with the kit or buy it separately?
                        • jaywood
                          • Jul 2010
                          • 4528
                          #312
                          The RPM/speedo/etc cluster? It's a KOSO unit. Waterproof. Made for motorcycles/jetskis.
                          We bought it separately from ebay IIRC.
                          • squidmaster
                            • Aug 2011
                            • 2666
                            #313
                            very cool!
                            BTW when engine management will you be using? stock subaru ecu with apv2 or standalone?
                            • jaywood
                              • Jul 2010
                              • 4528
                              #314
                              very cool!
                              The stock subaru ecu. Our tuner has offered to do open-source tuning for us. We were going to go with an aem standalone that would have separate tunes, one for e85 and one for pump) but e85 is nonexistent where we live so it would have been a waste.
                              • squidmaster
                                • Aug 2011
                                • 2666
                                #315
                                the apv2 can hold a couple of maps too. open source is the cheapest though, but with the apv2 you have built-in logging and ease of maps switching and uploading
                                I've run both OS and the apv2 and actually recommend the apv2 over OS.
