my e30: s50 w/6262 and a/c
    got my SI Shift light from e30 innovative good, can't wait to test it
      exhaust is almost done
      love those welds..
        Many thanks for posting the pictures with the strut bar in, I was wondering if that one would clear my downpipe and it looks like I won't have any issues!
          you're welcome
            exhaust is finished, and I'm picking up the car tomorrow!
              Burn out video tomorrow?
                went to pick up the car today, I was nervous, because I didn't know if it would overheat, leaks, etc; but everything went ok
                I need to change the speedometer gauge, abs is working now, so is the wideband, the car is making 8-9psi, feels great, but sometimes the afr goes to 9.8-10.0:1 and it breaks up, need to check that, I'm missing the on/off throttle response of the supercharger and 3.73:1 setup, but once everything is ok, it will be a lot better...
                also made the a/c work for a little time, the compressor has a small leak and it thrown all the oil, hope I can take it out easily...
                  still running rich, so made a boost leak tester, but only found a small leak from the throttle body to the fuel canister..
                  is good to have the car running again
                  installed the shift light, pretty good one, works as an SI light with acc, and different parameters when cold and hot, love it!
                    Bought a rear window blind
                      poor thin and small brakes
                      I already had these waiting to go on, if they don't work as expected, Im going with a bbk, maybe catuned or uuc...
                        and still running rich...
                        https://www.youtube.com/watch?v=4XclgZoWcd0
                          Looks great and quick wow! Thw shift light looks really bright in the video obviously. Is it more subdued in person?
                          Turbo M50 4 Door Build thread here 4 Sale thread
                            It's really bright, but you can adjust day/night brightness ;)
                              finally had time to use a better camera again and took some pics
                              here is one with my friend's project, an e30 m50
