my e30: s50 w/6262 and a/c
  • Mesarina
    • Jul 2012
    • 268
    #106
    time for the intercooler install...
    tight fit, need to find a way to route the a/c lines...
    another problem... not too much space between the water pump and radiator, even if I shave the water pump, the fan makes contact with the water pump pulley bolts
    waiting for my cylinder head to progress on another areas...
    • Mesarina
      • Jul 2012
      • 268
      #107
      ordeded a diesel fan, and took measurements using an e36 fan clutch...
      got another 90 degree mandrel bent pipe
      and my head is ready for the mls :D
      • e30m3s54turbo
        • Jun 2010
        • 3296
        #108
        Nice project. The fan is very close to radiator.
        • Mesarina
          • Jul 2012
          • 268
          #109
          Thanks. I still new to put the radiator upper base, there's space between radiator support and radiator, or I could shave the clutch nut to put the fan closer to the water pump, it will make the clutch engage early tough...
          • F34R
            sLaughter
            • 12376
            #110
            Killer build! awesome collection of cars too!
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • Mesarina
              • Jul 2012
              • 268
              #111
              cleaning the block..
              poor stock s50 pistons going to get all that boost :D
              bolting the manifold
              • Mesarina
                • Jul 2012
                • 268
                #112
                arps installed, fyi I had to install just one for alignment, in order to put the head on in an e30...
                after reading the forums and getting mixed reviews about the install of an mls gasket, I went with copper spray on it, has always worked on my cars, let's see if this one works...
                you can see the a/c line routing, it will need some kind of shield..
                e30's new look
                hope I don't have to cut the battery tray, downpipe piping barely fits..
                • E30NJ
                  • Aug 2013
                  • 921
                  #113
                  What kind of wheels are those? They look great!
                  • Mesarina
                    • Jul 2012
                    • 268
                    #114
                    Thanks, these are esm 002-r 16x8 and 16x9
                    • litu
                      • 849
                      #115
                      Awesome project, very interesting
                      https://www.facebook.com/Cry_77_IX-110483784967661
                      https://www.instagram.com/cry_77_ix/
                      • Mesarina
                        • Jul 2012
                        • 268
                        #116
                        Thanks Sade
                        yesterday I did a leak test on all cylinders since I already bolted the head... I was curious to see what % i was going to get for cyl 2, since I did a compression test before disassembly and these were the results
                        cyl 1 140psi
                        cyl 2 80psi
                        cyl 3 130psi
                        cyl 4 120psi
                        cyl 5 120psi
                        cyl 6 90psi
                        keep in mind we live about 5500ft above sea, so you could add aprox 20psi for each cyl, cyl 6 had water so it was a headgasket fault, but didn't know what happened to cyl 2...
                        on to the test
                        cyl 1
                        cyl 2
                        cyl 3
                        cyl 4
                        cyl 5
                        and cyl 6..
                        • econti
                          • May 2014
                          • 1152
                          #117
                          That's one hell of a turbo... Keen to see where this goes (probably sideways)
                          • Mesarina
                            • Jul 2012
                            • 268
                            #118
                            I hope not, this one is for going sideways.. ;)
                            • Mesarina
                              • Jul 2012
                              • 268
                              #119
                              made an oil pressure sender spacer with 1/8 npt for the oil feed line ;)
                              • Mesarina
                                • Jul 2012
                                • 268
                                #120
                                cams are back in the engine again
                                I'm going to powdercoat my vanos, termostat housing, valve cover, turbo, piping etc.. I haven't decided which color yet, I was thinking about smoke crome, since this is how it looks (some racing dynamics I did about a year ago..)
