6/83 grey market 323i.. mtech I S50 5-lug
  • kronus
    • Apr 2008
    • 13032
    #391
    annoyed-at-other-car-so-working-on-this-one updates!
    drove this guy around sears for a while to break in the new motor
    peeled off and rewrapped the interior harness - it's much nicer to be near now. I also teed the C104 tach wire and ran it out through the firewall so that I can splice it into the C101 and minimize wiring modifications for the S50.
    got the dash, windows, new c-pillar covers and seats in
    sadly I cocked up the SI board trying to replace the batteries, so no cluster for now. S50 is coming apart in the next few days and the head is going to the shop along with the M50 head out of the black car.
    cars beep boop
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #392
      Gimme that alpina wheel haha. Glad to see this car getting worked on. I need to do same to my car but the laziness is strong with me this winter.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • kronus
        • Apr 2008
        • 13032
        #393
        it stays with my Alpina seats..
        anyway, since engine-side square C101s are NLA and I don't want to hack up my L-jet harness (maybe someone will need it) I'll be putting a round C101 end on the chassis side of the harness, which will give me an opportunity to run some extra wire for things that didn't come in a square C101.
        cars beep boop
        • kronus
          • Apr 2008
          • 13032
          #394
          nothing major to report, but I have a probably-working-again cluster. After scrubbing the first attempt to replace the SI board batteries (the board delaminated and was rendered unusable), I got a new SI board and replaced the batteries successfully.
          this was a weird transitional year board that went from the long batteries to the short batteries by using a daughter board:
          my gf helped me out by replacing the odometer gears, reassembling the cluster and polishing the lens. The typical plastic headlight lens restoration kit you can get at autozone works well for this purpose.
          cars beep boop
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #395
            That cluster looks great gonna have to do that to the cover on mine.
            Let me know when your ready for the fabric ;)
            • pandaboo911
              • 2070
              #396
              Buy my engine
              • kronus
                • Apr 2008
                • 13032
                #397
                Originally posted by pandaboo911
                Buy my engine
                but i already have the s50 mostly torn apart
                tell me more
                cars beep boop
                • pandaboo911
                  • 2070
                  #398
                  • kronus
                    • Apr 2008
                    • 13032
                    #399
                    speaking of S50, here's most of an S50:
                    hi cams!
                    bye cams!
                    bye head!
                    and now it's off to the machine shop to have the guides fiddled with and the 60% leakdown corrected.
                    cars beep boop
                    • M-technik-3
                      • 18946
                      #400
                      Nice update. Need heat in my space so I can go back to work in garage. Was 4 degrees inside barn two days ago. Brrr
                      • kronus
                        • Apr 2008
                        • 13032
                        #401
                        that's not wrenching weather, that is huddling next to a fireplace weather. sorry to hear.
                        cars beep boop
                        • 2002jm
                          • Sep 2005
                          • 2076
                          #402
                          alpina seats
                          Looks really great....well not the si board:). Where did you get those alpina seats:)???
                          Jm
                          • 2mAn
                            SeƱior Mod
                            • 21005
                            #403
                            updates on this one since the black one is "done"
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • kronus
                              • Apr 2008
                              • 13032
                              #404
                              hah. ok.
                              I painted the fuel tank with rubberized undercoating and put in the front window lock strip. Pics tomorrow.
                              cars beep boop
                              • kronus
                                • Apr 2008
                                • 13032
                                #405
                                updates! surprisingly!
                                painted tank
                                painted trailing arms
                                they were originally going to be for the black car, but then I found my other set of trailing arms with bearings in them that aren't totally fucked. preferring to do one rear wheel bearing job rather than two, I decided to keep the good bearings together, and pull these 4-lug hubs out in favor of the M3 ones I've been sitting on. so here's a picture of that.
                                predictably the asshole inner races stayed on.
                                fixed.
                                I've been refrigerating the new wheel bearings for a few days, so those should be in soon. still no progress on the goddamn sunroof.
                                cars beep boop
