6/83 grey market 323i.. mtech I S50 5-lug
  • delamaize
    • Nov 2013
    • 1463
    #421
    *cough* M60 *cough*
    lol
    Dumpster Fire Pilot
    • 2mAn
      Señior Mod
      • 21006
      #422
      I got excited last night because I know someone who has a refreshed S52 block, but now I see you're looking for a S50 block... booo
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #423
        He can just sleeve those 3 cylinders there is nothing wrong with doing that. I know many people that have done it and couple that are running sleeved s5x's in race cars with zero issues. plus sleeving a cyl is like 60 a pop. that will be far cheaper then a new rotating assembly
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • kronus
          • Apr 2008
          • 13032
          #424
          sleeving cylinders is unfortunately not 60 a pop in the bay area
          also I want new pistons anyway cause these are all pocked up
          cars beep boop
          • kronus
            • Apr 2008
            • 13032
            #425
            yeah, I want to keep the s50 block cause bay area referees actually look at the numbers on it
            cars beep boop
            • 2mAn
              Señior Mod
              • 21006
              #426
              Is your crank still good? Can you just go to the S52 piston size? It nets you ~3025cc and makes it a slightly overbore setup.
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • kronus
                • Apr 2008
                • 13032
                #427
                s52 pistons need s52 crank
                edit: wrist pin is higher on s52 pistons because longer crank throw
                cars beep boop
                • 2mAn
                  Señior Mod
                  • 21006
                  #428
                  why? Im not challenging you, just curious.
                  I would even be tempted to use a M52 crank if you could and make it a real overbore setup with a 86.4mm bore and 84mm stroke. Still would be considered a 3L (2955cc)
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • kronus
                    • Apr 2008
                    • 13032
                    #429
                    s52 pistons with an s50 crank will lead to very low compression, the wrist pin height is higher on s52 pistons due to longer crank throw.
                    I haven't looked at nonstandard builds yet.. not sure that there's a convenient piston that I can use with an 84mm stroke crank.
                    cars beep boop
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #430
                      Well that sucks. Here I can get it done for 60 with labor or sometimes just for the cost of the sleeve. Whats a sleeve run out there?
                      • DER E30
                        • Sep 2013
                        • 2349
                        #431
                        Booooooooost????
                        -Christian
                        • pandaboo911
                          • 2070
                          #432
                          Nice 5 lug [emoji6]
                          Running e30 m3 rear brakes?
                          • kronus
                            • Apr 2008
                            • 13032
                            #433
                            Originally posted by pandaboo911
                            Nice 5 lug [emoji6]
                            yup, e30 M3 rears. got my hands on a set of caliper carriers and didn't see a need to figure out something bigger.
                            engine updates, got it torn down. here's some photos from the process.
                            an example of the scoring i'm dealing with:
                            In good news, I traded the S50 crank to Eric for his S52 crank and pistons, and arranged with Rebello to get the block boiled and bored out to 86.4mm, which should be happening in the next few weeks.
                            In the meantime, I am looking at bottom end bearings. Glyco's ok, yeah?
                            cars beep boop
                            • pandaboo911
                              • 2070
                              #434
                              In that case you'll have the exact same setup as I do. You'll probably have to shave the e46 carriers up front. Lmk if you got questions.
                              Ebrake lines are easy to remove/install fyi
                              • kronus
                                • Apr 2008
                                • 13032
                                #435
                                yeah, ebrakes are out already, went through all that with the black car.
                                not looking forward a ton to installing the fronts..
                                cars beep boop
