6/83 grey market 323i.. mtech I S50 5-lug
  • kronus
    • Apr 2008
    • 13032
    #451
    I did more things!
    the subframe is apart and powerwashed, the bushings are pushed out, and I've been working on making some reinforcement plates for the diff mount:
    these should more than double the metal thickness in this area.
    I'm waiting on our shop welder to be less fucked up, then these will get MIG'd on.
    I've also been attempting to decide if it makes more sense to put in adjusters, riser subframe bushings, or both. Leaning toward both, but would love some advice.
    cars beep boop
    • Bimmerman325i
      • 6854
      #452
      This is progressing WAY too fast now.
      2017 Chevrolet SS, 6MT
      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
      98 M3/4/5 (stock)
      • kronus
        • Apr 2008
        • 13032
        #453
        it might even be on the ground before the new year
        cars beep boop
        • kronus
          • Apr 2008
          • 13032
          #454
          in this update: a whole bunch of welding!
          these dudes got welded on
          reinforcement welds got cleaned up and primed with self-etching primer
          .. and painted
          trailing arm sway bar mount reinforcements got lined up with bolts (use your imagination for the other side)
          and welded!
          then it took me a few hours of whining and hurting myself to get all these fuckers onto the subframe:
          anyway, glad that's over with, because fuck that whole thing. a digital level like this one helps a lot.
          I might put it in now.
          cars beep boop
          • 2mAn
            Señior Mod
            • 20851
            #455
            shit... I need to go smog my car again one of these days... Id rather take it to the Streets of Willow though so who knows
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            -2006 Volkswagen Jetta TDI
            Make R3V Great Again -2020
            • kronus
              • Apr 2008
              • 13032
              #456
              a friend showed up and helped me steer this guy back home.
              brakes went on..
              and whee
              cars beep boop
              • efficient
                • Feb 2012
                • 3312
                #457
                I think you put in your subframe bushings upside down.
                • kronus
                  • Apr 2008
                  • 13032
                  #458
                  nah, that's the way those get installed. they raise the subframe relative to the car body, which keeps the rear geometry closer to stock.
                  cars beep boop
                  • ak-
                    • 12422
                    #459
                    The difference in rear tire wear is insaneeeeeeee after 0'ing toe.
                    1991 325iS turbo
                    • Bimmerman325i
                      • 6854
                      #460
                      I refuse to believe this car is on the ground.
                      (nice work!)
                      98 M3/4/5 (stock)
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #461
                        Oooh that's lookin' nice
                        • spiDmang
                          • 3941
                          #462
                          bad ass
                          91' 318iS - S54/6MT Swapped
                          08' E90 M3 6MT - Daily
                          Originally posted by IronJoe
                          Originally posted by 2mAn
                          • kronus
                            • Apr 2008
                            • 13032
                            #463
                            thanks guys! it's been a journey.
                            I hope so!
                            the car is having trouble believing it also
                            cars beep boop
                              • 37833
                              #464
                              I like the reinforcement plates for the diff mounting bolts. Gonna steal this idea for mine!
                              Grover Beach, California
                              BimmerHeads.com
                              • kronus
                                • Apr 2008
                                • 13032
                                #465
                                sweet
                                tip: the left and right forward mounts are not symmetrical, so don't just cut two of the same pattern.
                                also, good news! I bought pistons. I dropped them off at the machine shop about 15 minutes after I bought them, so didn't get a chance for a photo. However, the block should be back soon, and now I have everything to put it together.
                                ended up with Mahle first oversize pistons, the block is getting custom bored for them. using a S52 crank and the original rods from the S50.
                                the machine shop had to pull the oil sprayers to do the bore work.. should I get new ones, or are the original ones good to clean up and put back in?
                                cars beep boop
