Cirrus Saloon
  • ikonwun
    • Apr 2012
    • 374
    Cirrus Saloon
    Hello,
  • ikonwun
    • Apr 2012
    • 374
    So I picked up a E30 BMW in Feb I have been working on it and just got around to making a Proper Build thread.
    Specs
    1988
    CIRRUSBLAU-MET Saloon
    325e manual ( 250xxxmiles on swapped in IS cluster *unknown actual miles) I have come to believe the is one of the Super ETA’s that everyone loves.
    Its only revs to 5300, a 153 DME/1.1 motronic and has a 2.7 block with twin exhaust. Has diving boards with 89 front/rear lower valances.
    Car is Clean with no rust was from Texas now in AZ. I will be doing some light body work and a re-spray if I keep the car.
    No big plans for the car just daily status, Lower it and clean it up.
    It sat in a garage for 3 years before I bought it so lots of work was a head of me.
    I've started to do lots of the basic maintaince that it needs badly. see Repairs
    Here's what everyone wants!! Pics!!
    Repairs
    J-B welded vacuum nipple back into TB, Fuel filter (twice), spark plugs, new battery, new neg battery cable, new 3.0 FPR then a 2.5 FPR, New vacuum lines(FPR, valve cover breather, hard asfcuk under the manifold/behind the TB to evap canister hose), valve adjustment, new water pump , timing belt, sand blasted covers, new injectors and fuel rail, bypassed TB coolant thing, new cap and rotor, cleaned fuel tank, all new fuel lines, new fuel Pump, rebuild my driveshaft, Gasket matched /ported my stock cast exhaust manifold( for the fun of it), the welded in cat that was in the nasty stock smaller that IS twin exhaust clogged up. I found an ANSA exhaust locally and cleaned it up and installed it, the A/c system has been converted over to r-134a by BMW lucked out on that one ( it has a charge in it but it is weak and blows cool but never ICE cold I will revamp the A/C next winter), Front CAB’s are Delrin offset with new control arm ball joints
    Crazy no fun stuff
    Well I have been chasing a miss in cylinder #3 the last couple of days I have solved it... It was an injector stuck open.
    Then I decided to pull my injectors and rail. When i got my injectors out I found this...
    Wicked clogged number 3 injector. Which is weird because my number 3 cylinder was sticking open. Maybe full of dirt.
    I also rebuilt the full drive shaft. Unserviceable my @ss.*
    long story short I had to pull my gas tank to have it cleaned. I hate rust ! but now all like new!!!!
    Suspension
    Kw springs *Thanks Cody
    Bilstien sport front shocks*Thanks Cody
    M3 offset cabs Delrin.
    painted black BMW bottle caps with new tires. *Thanks Cody
    To install still
    New tie-rods with spacers
    Stainless steel lines and ABS delete lines
    Purchases on hold till wheels build is finished
    E90 spring hats
    Camaro rear shocks
    Exterior
    Stock
    Tucked bumpers
    Then I addeda lip *MK3 2.0 ( I had it all ready)
    Need todo
    Tint windows and shadow line the trim. Repaint mirrors black. Will re-spray next year after all body work is done.
    Interior
    Stock with EBay Sprayed black racing seats ( free to me better that the stock ripped ones) .
    I am looking for new stock interior but not high priority
    Need to do.
    TINT ( live in AZ)
    Finish cleaning carpet
    WHEELS
    Wheel specs
    16x8 16x9.5 Elipson/ SoutherWays built in '83 5x130 bolt pattern.
    Swapped lips and barrels around with a buddy and got 4x628 (3in) lips, 2x652(5.5in) barrels, 2x667 (7.75in) barrels
    Testing new wheels on the car before I refinish them
    Front Side
    Front top
    Rear side
    Rear top
    Rear
    Both side
    Closest fitment I can find
    Wheel specs
    Front
    16 x 8
    20mm adapters
    Rear
    16 x 9.5
    20mm adapters
    I will get ET and Back spacing when I have time.
    I will be building these for the next couple of months.
    Centers will be media blasted to raw alum and cleared ** Started
    Bolts will be yellow zinc coated dropping off 6/7
    Lips need flaking chrome removed and then full hand polished
    Will be dropped off for chrome stripping 6/7
    Barrels will be Painted Black
    Rolling and pulling fenders to make this work . I might run a 15 wider adapter in rear
    • pacmanE30
      • Dec 2010
      • 1524
      noice! you're off to a great start! but for some reason the links aren't working.
      *edit - nvm you fixed them. Great looking wheels!
      NRG Quick Release/MOMO Hubs|NRG Limited Edition Deep Dish Wheels|NRG Wood Wheels|Nardi|
      9five Eyewear|Day of the Dead Tees|
      WORK Wheels|Lug Nuts|
      STÄTUS|
      Got Juice?|
      • DEV0 E30
        • Oct 2004
        • 8896
        AZ E30s coming out of the woodwork, welcome.
        Sign up on azbmw.org for local meets if you haven't already.
        • 2mAn
          Señior Mod
          • 20967
          how much of a pain was it to mount the VW lip? I have one that I am going to install, but Im more concerned about getting the car running first so its on the back burner
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • matthugie
            • Mar 2004
            • 1810
            That's a nice start! Looking forward to where it goes from here.
            88 325is - S52 powered
            Originally posted by King Arthur
            We'll not risk another frontal assault, that rabbit's dynamite!
            • ikonwun
              • Apr 2012
              • 374
              yes Im Waygone (old e34 wagone) on azbmw and French-e on that azbmwcrew site. I haven't gone to any GTG yet.
              • ikonwun
                • Apr 2012
                • 374
                Not hard had to cut all the little "tags" off the back and it goes on pretty easy I used sheet metal screws to do it I still have to finish trim the edges.
                • NC318e30
                  • Aug 2011
                  • 170
                  I run 16x8 style 5s with 18mm adapters in the front and 20mm in the rear. Factory offset of 23 so if you look thru my posts you will find some fitment pics that will be somewhat similar to yours bud! Love the wheels!
                  • ikonwun
                    • Apr 2012
                    • 374
                    Finally the bolts are off to ZINC and lips are off to the chrome stripper!!!!!
                    Now I have to get the faces done sandblasted and the barrels cleaned and off to powder coat. I need to do work!
                    I ordered lots of little BMW parts today clips and what not. The cover under the driver's side of the dash came off and all the wires are finally getting on my nerves.
                    I'm fixing the spare /bad oil pan I have. It had stripped out threads beyond repair. I'm thinking about putting a turbo drain on it just in case I go crazy later on.
                    This weekend I should be installing a new oil pan and flushing the rad and refilling with distilled water and some coolant.
                    • ikonwun
                      • Apr 2012
                      • 374
                      Wheels / parts update
                      Wheels how they started
                      Here is the color scheme I’m going for Polished lip, raw alu center and yellow zinc bolts
                      Not mine closest pic to what I want I could find.
                      So I the lips got picked up from me to get stripped on weds afternoon on Thursday Frank came back with these all stripped and ready to polish!!!!
                      Also got some vintage NOS Porsche center caps for FUCHS. Fits in my elipson’s very nicely
                      I had a spare oil pan that had the dreaded stripped drain plug. So I make a plug at my works fab shop and then had the Man Al weld it for me.
                      I got lots of little parts, clips, air filter and oil pan gasket CORK ftw.
                      I have extra grills and will start the next cosmetic project for the front end ( flame suit on)
                      This is the car that made me want to get my e30. I’ve looked at it for years. I’m an ex VW guy.
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        finally saw this build. I approve!
                        2014 Alpine White 335i MSport
                        (Daily Driver)
                        Full Mperformance Aero
                        KW V2 Coilovers
                        VRSF Catless Downpipes
                        • ikonwun
                          • Apr 2012
                          • 374
                          I know you. when you getting back ?
                          That other oil pan was missing a chunk and could not be repaired.
                          I dropped off my injectors off at azspeed this morning for flow testing and cleaning. wont get them back till Monday. so car is down all weekend will be doing lots of fun stuff to it .
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            Haha, I told you that in the text. Would have needed stupid amounts of cutting and welding to fix that corner.
                            Early august.
                            (Daily Driver)
                            KW V2 Coilovers
                            • sgmira_e30
                              • 89
                              Mike Put you your high beams back in!!!
                              ps. good work, like the write up
                              1989 325i 5Lug S52 - RIP 1991 325i S52
