Melted a piston, now LSX Turbo
    Found a set of bbs rc041's on craigslist the price was right and they are forged and 1 of 150 sets I've been told. VRwheels will be making lips and barrels for them, and I will get the centers polished.
    Bang Gears & Burn Rubber.
    Instagram: @Dirk_LSXT
    Buy my m20 racecar parts, help fund my lsx turbo swap.
      Sorry if it's a dumb question, but why weld the trunk shut?
        So people cant get out, duh :D
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
          This. What happens when you need to replace shock mounts.
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
            maybe I missed it, but where did he mention welding the trunk shut?
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
              I think he meant to say "trunk shit"
                cool build, I wonder whats the difference in the output shaft splines on the 210mm differential? My bud's boosted e21 just shredded the splines on his output shaft splines on his 168mm diff. And I'm pretty sure that small case and medium case axle output stub splines are interchangeable between the diffs, I'm curious if the large case has beefier splines?
                  The floor of the trunk was cut out and welded shut for the fuel cell and pumps.
                  Thanks, I can try and measure them when I get a chance, but I believe they are beefier and interchange between all 210mm diffs.
                    Ah that makes more sense.
                      Bought some more parts. Wilwood manual pedal setup because the booster doesn't clear, shaved valve covers (don't worry I'm going to powdercoat them), AN fittings for breather setup and oil feed/drain, and coil relocator brackets.
                        I read the whole deal, this is one sick machine man!
                        1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
                        1984 316 Coupe - The Base Model - Pain in the Ass
                        1988 750iL - The Daily Driver
                        ...And a couple others...
                          Where did you get those valve covers? I looked for something like that for mine and couldn't find anything like that.
                          2003.5 Imolarot M3: daily
                          1995 Alpinweiß M3: hpde
                            Any updates? This is killer
                            24v swapped
                              Thanks!
                              They're ebay specials, I'll find the link to them.
                              Thanks, here's some updates.
                              Rear end is all sorted now.
                              E36 diff with a 4 clutch rebuild and 3.46 gears, CAtuned chromoly axles, z3 hubs, e46 brakes, camber/toe adjustment tabs welded in, raised subframe 12mm, cut and boxed/reinforced subframe to clear 1350 u joint.
                              Had to mill part of my diff to accept the 2 extra clutches.
                              New bolts, bearings, and clutches
                              It's going to be a tight fit, I still plan on reinforcing the subframe a little bit more just for peace of mind.
                              Next step is to machine an adapter to bolt the 1350 u joint flange to my diff input flange.
                              There's not much left to do for the car overall.
                              -Decide on front brake setup
                              -Wheels and tires
                              -Measure for driveshaft
                              -Make crossover and exhaust
                              -Buy radiator
                              -Finish intercooler piping
                              -Buy seat covers and harnesses
                                not sure if you knew this, but jagsthatrun.com sells a flange that bolts right up to the e30/36 6cyl diff for $100
