Dad and Daughter E30 project
  • Xat1cZ
    • 2020
    That car looks like a great start.
    Originally posted by LJ851
    In before r3v.
    There will be no shenanigans.
    • Hooffenstein HD
      • Nov 2012
      • 1388
      Needs more 5 speed swap.
      • Petunia
        • Aug 2013
        • 16
        Day 2:
        Thanks for all the comments you have posted! No plans for the car yet other than to get it running properly and change the brakes so its safe for me to drive when I turn 16 next March.
        Today we started with removing the fan clutch so we could get to the timing belt. We had some problems with taking off the fan clutch because we didn't have the right tools but finally got the bolt loose with a 32mm wrench from the bicycle store.
        Next we removed everything to get to the timing belt. We did have a problem getting past the rotor because the 3 mm Allen head screws were stripped by the previous owner. My dad just broke the rotor so we could take off the upper timing belt cover. It was a pain!
        After that we got the timing belt off where we saw this:
        Have you ever seen a timing belt fail in this way?
        The teeth were stripped down at the bottom of the engine on the crank.
        Well either way we continued on disconnecting all the intake hoses and electrical plugs to get ready to remove the head. We have been using the Bentley manual that my dad had when he used to have a BMW E30. We also found a few links on the internet that are helping us along.
        It looks like the only thing left holding us up to get the head off is the exhaust manifolds. They are causing my dad a lot of troubles. We have got all the nuts off except the 3 bottom nuts on the manifold closest to the firewall.
        Any tips on getting these off?
        We tried taking the 3 nuts off where the manifold connects to each exhaust pipe but they won't budge. Either way they are soaking in this fluid my dad calls PB blaster to hopefully loosen them up.
        Well.. That's it for now. We probably won't be back on it till next week so stay tuned!
        • deutschman
          • May 2008
          • 5958
          For the exhaust manifold, it will be heavier, but just unbolt the exhaust from the manifold and take the head off with the manifold still attached. That way you just flip the head upside down on the work bench to get to those pesky nuts on the bottom of the manifold.
          • Redfox
            • Jan 2011
            • 834
            inb4 perv r3v comments.
            Which I am in shock haven't happened already. Getting soft around here.
            • E30 Wagen
              • Jul 2005
              • 3434
              I would also just leave the exhaust manifolds on. With them out of the car it would be a good chance to clean them up inside and out, sandblast and then repaint with some high temperature header paint. Having nice looking manifolds cleans the engine bay up a lot.
              Hopefully there's no damage to the piston/cylinder with the broken rocker arm.
              Also, that looks like a really clean e30! Should be a really nice first car; it's cool to see them revived and driven again.
              My Feedback
              • Holland
                • Nov 2008
                • 7212
                I would expect in this thread, the upmost dignity even for our lowest standard members.
                Originally posted by DEV0 E30
                • Redfox
                  • Jan 2011
                  • 834
                  I wouldn't put anything past some of them. *cough* Robert Scheiring *cough*
                  • Cletonius
                    • 2809
                    Excellent project! Your dad sounds like a pretty cool guy to get you an e30 for your first car.
                    - Josh
                    1990 325is
                    Need a shift boot?
                    Looking to buy shift boot frames, PM if you have one to sell
                    Here's what happens when you let the internet pick your license plate
                    • aPapester
                      • 215
                      Awesome first car! It was mine too, 5spd swap and you'll have alotta fun driving it
                      Check Out My Photography
                      aPapester Photography Facebook
                      • deutschman
                        • May 2008
                        • 5958
                        My first car was a 1976 2002 :)
                        • Zreberlcoe
                          • 1555
                          YOU LUCKY BASTARD:hitler:
                          Anyways, welcome to the fun and your soon addiction! I got my first car as an E30 as well because honestly there isnt a better car for us young drivers. The process on mine has been very slow until now but it looks like you have a little rougher start then I did although I just did a timing belt this past weekend as well! Good luck with it all!
                          1991 325i Calypso Coupe
                          Like Grandfather, Like Father, Like Son
                          BMW
                          • F34R
                            sLaughter
                            • 12376
                            My Baby sister(19) has an e30 and she really does not desire to work on it at all. Glad to see another young lady joining the ranks.
                            R3v is the best place for ANY BMW info.
                            Welcome to r3v, I hope your Dad is the one posting here...
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • enigmaticdream
                              • Jan 2010
                              • 572
                              DELPHIN!!!! Sweet project!
                              1986 911 Supercharged Frakenstrat/Stripped
                              1987 325is Delphin/Black (Olga)
                              1988 M3 Zinno/Natur (Elsa)
                              Manual or STFU
                              E30 Chapter of BMW Car Club of America
                              E30 Oktoberfest 2017
                              • Ether-D
                                • Sep 2011
                                • 2838
                                Good job to you for helping your Pop fix up your first car. And good job to your Dad too. It's the same color and year as my first e30. Only mine was a 5-speed. Love it and don't ever sell it. It will just haunt you if you do...
                                edit: It is real easy to get to the 3 exhaust flange nuts from under the car with a ratchet, about 18" of ratchet extensions, and a wobble adapter. The two most rearward manifold nuts are best removed (IMO) with a 1/4" ratchet and 12mm socket with a 4" extension. The third, "hard-to-get-to" nut, doesn't need the extension.
                                Originally posted by Andy.B
                                I was born on 3/25…
