ITB's on a 24v project, Dyno results Post 136!!!
  • nyChris
    • Apr 2012
    • 395
    #166
    Originally posted by jrockbk
    I'm confused as to why it can't fit on e30 vs e36 if it's bolted to same motor, what won't clear? You mentioned something about the oil filter housing but isn't that bolted to the motor as well? Or is it different b/c hood won't shut? When do e30 kits become avail?
    Clearance of the strut tower, and/or brake booster I would assume. e30 engine bay is a bit smaller than the e36.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #167
      This exact setup won't fit an e30 with a brake booster (well, will physically clear). There should be at least one throttle diameter away from any obstruction, and that just won't happen in an e30, even with a small booster. Booster delete is fine.
      The oil filter housing issue was resolved with an updated casting with more angle to clear. This was only an issue on the metal oil filter housing cover, it cleared the plastic ones only. All this has all changed and been resolved (obviously, they are bolted to the motor and running now).
      If you would like these in your e30 with a brake booster, we just send you slightly shorter throttle housings, everything else is the same.
      So, in short, all the fitment issues have been sorted for both chassis, and for all single vanos engines. I believe they will fit dual vanos engines, specially seeing some m54 guys have started swapping to the obd1 manifolds - these throttles are pretty much the same size as an m50 manifold...
      So, while the longer throttle housings will clear the booster, it won't have the one diameter clearance rule for open trumpets.
      For those interested in putting them on an m52tu, or m54, see this thread...
      john@m20guru.com
      Links:
      • jrockbk
        • Jun 2013
        • 369
        #168
        http://forum.e46fanatics.com/showthread.php?t=1030015
        Thanks for such a clear answer, stacking my chips! Do you accept bit-coin lol! Just joking
        • ForcedFirebird
          • Feb 2007
          • 8300
          #169
          Sure! Right after they are converted to USD ;)
          john@m20guru.com
          Links:
          • kingston
            • Jun 2010
            • 2669
            #170
            Is there a plan to offer a tune & airbox for the E30 24V swaps? So excited about this!
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
            • ForcedFirebird
              • Feb 2007
              • 8300
              #171
              Tunes are available for the open trumpets.
              Air-boxes are in the plans, yes, but will be more expensive. We will be starting with sheet metal, and pending serious interest, carbon can be manufactured.
              More on this later, though, the parts for the new setup just arrived. Trying to talk a couple locals into putting these on their 3 and 3.2l motors and re-dyno them just to prove further how they perform.
              john@m20guru.com
              Links:
              • LJ851
                • 7919
                #172
                So which ECUs are you able to alphaN with now that you figured this out? Can m20 and m30 be made to do this?
                Lorin
                The M30 is God's engine.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #173
                  Yes.
                  john@m20guru.com
                  Links:
                  • jrockbk
                    • Jun 2013
                    • 369
                    #174
                    This may be a silly question but, how safe is it running this setup with just the trumpets and no air filtering?
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #175
                      We are having little filters made for those that want to run open trumpets, also a plenum in the works for people wanting to use the MAF and/or boost them.
                      john@m20guru.com
                      Links:
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        #176
                        The short answer is that it's not safe for the long term on a street driven car, but it makes good PR videos.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #177
                          Originally posted by The Dark Side of Will
                          The short answer is that it's not safe for the long term, but it makes good PR videos.
                          And it's fine on the track. Many many cars out there run open trumpets, on ITB's and Weber alike. With the obvious state of this engine, I not only have been driving it without filtration, but hood-less as well.
                          john@m20guru.com
                          Links:
                            • Jun 2010
                            • 2796
                            #178
                            Fixed ;)
                            • mkcman17
                              • Jul 2010
                              • 8240
                              #179
                              I love being on guinea pig runs - let me know. I've got money set aside for the s50 car.
                              1989 LN106 Hilux / 3.0TD SFA
                              1974 2002tii / stock
                              2002 IS300 / 5spd LSD
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #180
                                Ready when you are.
                                john@m20guru.com
                                Links:
