ITB's on a 24v project, Dyno results Post 136!!!
  • LJ851
    • 7919
    #121
    Originally posted by ForcedFirebird
    Not sure the OEM mounts are happy, but quick vid during a tuning session...
    Where should i send the dry cleaning bill for my shorts?
    Lorin
    The M30 is God's engine.
    • Dj Buttchug
      • Jun 2010
      • 7687
      #122
      Originally posted by amcink
      Take my Money NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • MyE30
        • Sep 2013
        • 326
        #123
        are you sure that motor is bolted down!?
        don't get that e36 impounded for too much power!
        • ForcedFirebird
          • Feb 2007
          • 8300
          #124
          I was just as surprised when watching the video. We gave the car a good look over when it was on the lift to get WB bung welded, even pried on the mount arms, they didn't feel like they leaked out, and there was no cracks in them.
          john@m20guru.com
          Links:
          • Good & Tight
            • Apr 2004
            • 2057
            #125
            Sounds amazing John..!!!!!
            Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
            ____________________________
            E-mail Panayiotisx2@gmail.com
            Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
            • kingston
              • Jun 2010
              • 2669
              #126
              You seriously need to add "NSFW" to the title of this thread, `cause that sound is pure PORN!
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • bmwandhonda
                • 646
                #127
                ooooh yes!!
                E30 325i Touring currently under construction.
                http://www.r3vlimited.com/board/show...256444&page=20
                • Eljosh
                  • 244
                  #128
                  Greatest video sound on the internet.
                  • Jim Lepage
                    • Jul 2008
                    • 1138
                    #129
                    Update ?
                    Video ?
                    Dyno results ?
                    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #130
                      Originally posted by Jim Lepage
                      Update ?
                      Video ?
                      Dyno results ?
                      Dyno, no
                      More video of an m50 destroying mounts, no.
                      Updates...well, the ECU isn't happy sans MAF, so it's not a simple process to make it do things it wasn't intended it to do - but it's getting more tame.
                      john@m20guru.com
                      Links:
                      • Jib05
                        • Aug 2012
                        • 149
                        #131
                        I think my 3litre needs these.
                        .................................................. ...................sigpic
                        .................................................. ............................. ......M50B25 3.1L stroker
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #132
                          Fresh cold start and drive around the block. OBD1, still MAF delete on a 413 red label...
                          john@m20guru.com
                          Links:
                          • LJ851
                            • 7919
                            #133
                            ^ You got straight cut gears in that thing ?
                            Lorin
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #134
                              I have no idea why it makes that noise. This car is seriously a huge POS, but the motor is strong. Light flywheel so it sounds like a rod knocking at idle in N, interior is trashed, paint has no clear left, pops out of reverse, leaks oil, leaks PS and the trans sounds like a supercharger. It does have DDM coil overs, new control arms, tie rods and other tidbits, but whatever. These ITB's is the only reason I got it. Traded it square for my wife's Honda Odyssey with a slipping trans. I have known the last 5 owners and it always whined like this, has fluid and shifts fine (except having to hold it in reverse). Haven't verified if it's the original engine, but the clock shows just over 200k.
                              Once the testing is done, probably going to throw a cage in it, spare ZF, stock suspension and intake, then take it out to ChumpCar.
                              EDIT: Oh yeah, also can see the parking lot through the battery tray, so it's got rust too :/
                              john@m20guru.com
                              Links:
                              • Wanganstyle
                                • 2828
                                #135
                                Awesome. I wanna race lemons with trumpets but hidden in a fiberglass reinforced milk container with a yogurt cannister based cone filer
                                Sent from my SAMSUNG-SGH-I337 using Tapatalk
