ITB's on a 24v project, Dyno results Post 136!!!
  • ForcedFirebird
    • Feb 2007
    • 8300
    #196
    Originally posted by Jaker
    More info?
    6-3-1 system where there are triple 2-1 collectors, coming from the two cyls that are TDC. IE pairing 1-6, 2-5 and 3-4. It makes a very unique exotic sound - think flat plane crank without changing the crank - it gets emphasized with individual throttles.
    john@m20guru.com
    Links:
    • ThatM20Guy
      • Aug 2014
      • 600
      #197
      Any headers that are made like this for an m20 Or would you have to fab your own?
      89' 325ix Diamantschwarz/Black rattle can...
      Insta: r_moose_w
      Originally posted by flyboyx
      I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
      • digger
        • Nov 2005
        • 6197
        #198
        how is the packing with it? usually its a pita to fit.
        • ThatM20Guy
          • Aug 2014
          • 600
          #199
          I have POS ebay headers currently, so I am thinking I might fab some up for 'fun'
          Insta: r_moose_w
          • varg
            Florida Turbo Man
            • May 2014
            • 3429
            #200
            How is the packaging on a 6-3-1 style header in an E30? Sounds tight.
            IG @turbovarg
            '91 318is, M20 turbo
            • digger
              • Nov 2005
              • 6197
              #201
              run primaries that tune into a useable rpm 26-30" makes it even harder and longer secondaries such that you also end up with 3 pipes bundled under the chassis which might hurt ground clearance (might be no worse than 4" OD CAT or 3" single pipe as further back you can have a single pipe or twin ? on a RHD it would be even mor fun with steering linkage but not an issue for you guys. certainly has potential improvements over 6-2, ive thought about it recently but im trying to model it and quantify the improvements down low and midrange. for me its probably not practical so ive come up with a 6-2 design that i might get made oneday
              • ForcedFirebird
                • Feb 2007
                • 8300
                #202
                Custom made, but seeing this is a thread about a 24v, not m20, it's actually going to be even a tighter fit.
                Since you are 2-1, the secondaries can be much smaller.
                john@m20guru.com
                Links:
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3429
                  #203
                  That was my point about it being a tight fit. I want to see this header when it's done.
                  IG @turbovarg
                  • digger
                    • Nov 2005
                    • 6197
                    #204
                    yes, of course the slant is worse so more room for inlet side of things but less on the exhaust..
                    what did you find from that exhaust you did?
                    i did some system modelling and the main benefit seems to be right down low like sub 2000rpm.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #205
                      I know you are busy with school, but if you stopped by more often, you would get to see a lot of stuff :P
                      john@m20guru.com
                      Links:
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #206
                        I ended up in a bad accident in that car, it's long gone. The collector set has been sitting on the shelf since, now a customer wants them, so they will finally get put to use.
                        john@m20guru.com
                        Links:
                        • ThatM20Guy
                          • Aug 2014
                          • 600
                          #207
                          I was meaningto say fabricate a 6-3-1 for an m20
                          Will be interested to see how they fit with a 24v
                          Sorry to get the thread off topic-ish
                          Insta: r_moose_w
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #208
                            My m20 was supposed to be the engine they went on, but this thread is so old, have at it! I'm currently parting the e36 the ITB were tested on...
                            john@m20guru.com
                            Links:
                            • Jaker
                              • Oct 2013
                              • 234
                              #209
                              Damn! Too late for me:
                              • AWDBOB
                                hooptie connoisseur
                                • Aug 2013
                                • 4504
                                #210
                                Anyone install these (RHD) on a 24V E30 yet?
                                Wondering if a 944 or 2002 booster moved over w/modified clevis would work?
                                Remote master?
