88' Zinno M3 (Progress Thread)
  • tak7
    • 856
    #76
    I like the plate filler with the bumper tape.
    Beautiful car and great work!
    • jhaurimn
      • Nov 2012
      • 2224
      #77
      Hmmmm...look what we got here... update to come later today :)
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • jhaurimn
        • Nov 2012
        • 2224
        #78
        Finally have some proper wheels and tires on :) 225/45/16 is a tough size to get
        Sun didnt cooperate... Putting them on, I noticed these. Didn't know about them until now. Finally a nice surprise. I noticed earlier the shocks were bilsteins when looking under the car
        I will get better pictures once its nice enough to take it out.
        In other news, I repainted my tow hook covers and bumper cover. They were just slightly off, but the paint I got when I did the brake ducts matched a better, so I decided to repaint them. Hard to tell but they match better.
        Next up is to remove the tint and install the stromung muffler
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • jhaurimn
          • Nov 2012
          • 2224
          #79
          Small update.
          I got the fender liners on. I tried when putting on the wheels, but some issues made it a little tough to get them on and I was excited to get the wheels on. I know these pictures are a little boring but I couldn't find any good pictures online showing the hardware needed and where it goes.
          There's the main liner piece that attaches on the back of the fender with two bolts that go into existing expanding rivets in the wheel arch. There is another hole near the side skirt. It looks like this just slips over the stud that's there, but doesn't get tied down. It attaches at the top with two plastic nuts on existing studs. The front is what gave me problems. It looks like there should be a bracket to attach a body nut and screw in, but mine were all rusted and bent. I needed to carefully bend these back, enough to stick an expanding rivet in. Then I was able to screw it down.
          Then came attaching the intermediate part, as BMW calls it. It attaches with two body nuts and two screws. It's held on with the bottom of the front bumper, and by the main liner piece.
          Glad I bought oem size tires, as I shouldn't run into any rubbing issues.
          I hope this helps somebody. Let me know if you need part numbers
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • euroshark
            • Apr 2006
            • 3491
            #80
            Awesome project! I love watching this car improve bit by bit.
            • jhaurimn
              • Nov 2012
              • 2224
              #81
              Got the car out today. :)
              I did a few things
              -replaced ebrake handle
              -replaced third brake light bulb
              -replaced window trim pieces on pass side
              -ordered trim pieces under rear bumper
              Hoping its nice enough out next Saturday to bring her out to cars and coffee :D
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • Bimmer_man
                • Jan 2013
                • 1477
                #82
                Damn dude that thing looks like it came off the show room floor.
                Float like a cadillac sting like a Bimmer!:)
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #83
                  So today I took care of a few things with my cluster. Taking the cluster out is something that might take awhile the first time, but really is very simple. I had a refurbished board from Greg to put in
                  I also had a good working led panel from his as well. The other main reason I pulled the cluster was the left illumination bulb was burnt out, so at night I had no idea how fast I was going. They are the larger bulbs that aren't in a socket. The small green bulbs are extras I bought in case any needed replacing.
                  Back of the m3 cluster. Had a weird plug I hadn't seen before that I'm guessing is for the oil temp
                  Let there be light
                  So as I'm sitting in the car enjoying all the lights working, I can't help but notice my defrost button doesn't light up...
                  That's better
                  Still not sure what route I want to go on the stereo/headunit
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • Bimmer_man
                    • Jan 2013
                    • 1477
                    #84
                    in my opinion i think you should keep the oem head unit. or save some bucks and get a oem CD player for the M3 and have it worked on cause from what i recall they skip like hell. Go for a concorse restoration ^_^.
                    • jhaurimn
                      • Nov 2012
                      • 2224
                      #85
                      Things are warming up for good. After getting 8" of snow Thursday, I am ready for spring weather.
                      The hazet 880amgt spark plug tool came. It was over $50, but was worth it, as any other spark plug socket has to be ground down to fit. So I replaced the plugs, and checked condition of the plug wires and distributor cap. Wires and cap look good. The wires are the red evo version, so it was replaced at one point.
                      Old plugs, it was time.
                      I went ahead and replaced all the engine decals. Most of them came off pretty easy.
                      This one was a PITA to remove, however.
                      You can see some of the wiring was wrapped in some janky looking tape. So I re-wrapped it with oem tesa harness tape.
                      Engine bay is getting there. I also put in the middle harness cover and wiper fluid bottle. I'm thinking about pulling the valve cover this week to get it powder coated. With that and a new coolant bottle, the engine bay should be looking great :)
                      And here's a shot from cars and coffee. More maintenance stuff coming soon.
                      Current:
                      1989 325i
                      1988 M3
                      1987 325ic
                      Past:
                      2001 330ci
                      2001 M3
                      • SteadyAim.
                        • Jan 2013
                        • 249
                        #86
                        Everything looks great! Hope to pick up another one in the future
                        '90 Alpine White M3
                        OEM Hella Smoked Euro Smileys | OEM Headlamp Washers | Startec Tail Lights |
                        EVO III Undertray | EVO III Front Lip | '92 DTM CF Gurney Flap | Recaro N'Joys |
                        Ground Control Coilovers | OZ Futuras
                        DD: '97 Alpine White M3/4/5
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #87
                          Dude where are you getting all this oem stuff?
                          • M-technik-3
                            • 18946
                            #88
                            Discontinued tire here folks so these are gonna go fast. Dunlap has a new Star Spec coming out.
                            • jhaurimn
                              • Nov 2012
                              • 2224
                              #89
                              Like what? The stickers are from pukardesigns .
                              Current:
                              1989 325i
                              1988 M3
                              1987 325ic
                              Past:
                              2001 330ci
                              2001 M3
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #90
                                Heres a few more from cars and coffee this satuday. Nice to see all the little things are making a difference.
                                All photo credits go to the rightful photographers
                                I edited this one a bit. Didnt spend too much time on it
                                And this one in route to cars and coffee with my friend Erik and his 850i 6 speed. (v12)
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
