88' Zinno M3 (Progress Thread)
  • archie
    • 5448
    #46
    YES! He adds the bumper tape! Was gonna ask but just saw it.
    Bumper tape on the E30 M3 is like a frame around a beautiful photo.
    88 M3 Diamantschwarz
    89 M3 Zinnoberrot
    56 Isetta
    LIKE ARCHIE'S on Facebook!
    • bradnic
      • Jul 2012
      • 3554
      #47
      Booya on both the tape and the Strömumg :-)
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • jhaurimn
        • Nov 2012
        • 2224
        #48
        Thanks guys :) bumper tape really does complete the look of the car.
        I havent been doing much lately, as temperatures here have been subzero for over a week. Its been miserable actually. I brought the m3 over to fix the fuel line which meant my daily 325i got stuck outside. Then this happened...
        I bought some oem premium speakers to replace the aftermarket ones. My intent was to have everything stock. But now Im not sure if I should do that or go with better performing, subtle looking speakers. Thoughts?
        And a preview of whats next...
        I found out that trim piece Raul was talking about that goes into the oil cooler comes with the front bumper, and cant be bought seperately...does anyone have an extra one?
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • ksjdan
          • Jul 2012
          • 330
          #49
          Excellent choice of dye. If you want a good result, you should use a aerosol sprayer.
          My 1990 325is Build Thread
          • jhaurimn
            • Nov 2012
            • 2224
            #50
            After ordering everything, I realized leatherworldtech sold a disposable spray gun to spray the dye. So I am waiting on that to arrive now :)
            Edit: And now I just discovered preval is at homedepot! I will probably give that a try so I can conquer the seats this weekend. So excite
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • jhaurimn
              • Nov 2012
              • 2224
              #51
              Well, heres the results of the leatherworldtech kit. I tried using both preval and the crown spra tool. Both did not work well with the dye. That being said, if you blot the final layer of dye with the sponge, it leaves almost no brush strokes and evens the dye out. If you have a compressor with an airgun, id absolutely reccomend using that.
              So heres what I started with. I didnt get good before pictures of the passenger seat, as it was in pretty good shape to begin with. The driver seat was the reason I went through with this.
              First, I had to take care of this rip.
              I bought 'liquid stitch' with my repair kit. While its not the best, it will keep the rip closed, so it doesnt keep catching on my pants and rip even more.
              You can see in those pictures the extend of the cracking. In this one you can see most bolsters are cracking as well. The thiegh bolster and upper side bolster in particular have seen better days.
              So, if you want more info or pictures on the process, I can post them or send them to you. But heres how the seats turned out after applying the leather filler, sanding it down, and putting on 5 coats of dye.
              Heres the passenger seat. There was much less cracking on this seat, so it looks almost new now.
              Very satisfied with the kit. I spent $100 on everything when it was all said and done. Waiting for the dye to cure completely before I throw them back in the car.
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • e30m3s54turbo
                • Jun 2010
                • 3290
                #52
                Your seats came out great!
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #53
                  I would very much appreciate that. Is there a "seat restoration" thread on R3V?
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    #54
                    Wow, those look brand new. Fantastic.
                    • Javier h
                      • Sep 2007
                      • 1189
                      #55
                      Seats
                      The trick, as I understand it, is to sand the cracks down and then apply as little filler as possible. What I did on my other seats was nearly strip the color...pretty much leaving NO CRACKS whatsoever on the seats. Be very careful. You dont want to go into the hyde itself either. I used a chemical to achieve this taking just a few seconds. Let that dry before sanding. Make sure also that you sand everything well before dying as it will make the paint stick, otherwise there is a tendency to peel. Then I barely applied anything (as far as filler was concerned) as it wasnt even necessary. The cracks will likely not come back as bad as if you filled it. Also, it helps if you let these cure a few months. This assumes you have extra seats. Nothing beats re-upholstering though but all things considered if done properly, you can extended the life a few years before sink money into buying new leather.
                      • YAN-3
                        • Jan 2004
                        • 6018
                        #56
                        well, this is nice to see. congrats on a M3 and keep up the great work!
                        • Nats88M3
                          • Sep 2013
                          • 209
                          #57
                          Damn that's some good detailed work... congrats!!
                          • jhaurimn
                            • Nov 2012
                            • 2224
                            #58
                            Thanks for the kind words guys! Im very excited with how the seats turned out.
                            Thanks for posting this info, good for me and others to know. I did put as little filler as possible down, and avoided heavy sanding as like you said I didnt want to go into the hyde. And unfortunately, our winter isnt going anywhere so these seats will be able to cure for awhile :p
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
                            • robrez
                              • Jul 2008
                              • 3376
                              #59
                              Thanks for the write-up. I needed this to get psyched for my own leather dye project. Can you provide more info. on the Liquid Stitch product. Is it a Leatherworld product too?
                              Also, in retrospect, do you think the cost/benefit analysis would favor taking the seats apart prior to dying? Or do you think it wouldn't be worth the extra work?
                              BTW, a full-write-up on the seat dying process would be awesome. I know there are already a couple DIYs but it's nice to see different peoples' perspectives. And your seats came out well.
                              January 2012 COTM
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #60
                                Yes liquid stitch is a product they sell. It worked good but is hard to make it look nice. If you are using it before dying the seats you should be okay.
                                I got into most of the hard to reach areas, so it's not required. However taking the seat back off of the seat bottom is a good idea. You'd have to try really hard, pressing the leather to look into the deep creases to see the parts I missed.
                                I might post up some more pictures tomorrow that shows a more step by step with a description of what I did. But it's really pretty straight forward, I just followed the directions they give you :)
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
