E30 Oem m3 sheet metal conversion
  • jburnsbmw
    • Oct 2012
    • 142
    #76
    Wheels arrived! Apex arc-8 flat black 19x9.5 et33 rear and 19x8.5 et35 front. Will roll front fenders and rear quarters. May trim rear quarter inner wheel housings depending how well they fit.
    E30 Oem M3 Sheet metal conversion build
    http://www.r3vlimited.com/board/showthread.php?t=308422
    https://instagram.com/jburnsbmw/
    • e30m3s54turbo
      • Jun 2010
      • 3290
      #77
      Wheels look nice. On my inner rear quarter I ground down the inner lip to fit 255x40x17 on a 17x 9.5 et25 Hartge wheel. Good luck on fitting wheels.
      • jburnsbmw
        • Oct 2012
        • 142
        #78
        So instead of rolling you just trimmed the inner edge?
        • francogt1
          • Sep 2011
          • 269
          #79
          very nice keep it up
          • Thizzelle
            • 4422
            #80
            I don't think 19's will fit at all
            "I wanna see da boat movie"
            "I got a tree on my house"
            • jburnsbmw
              • Oct 2012
              • 142
              #81
              Anything is possible. I'll make them fit
              • jalopi
                • 2370
                #82
                anything is possible, but OP you've spent alot of money and gone out of your way to make this car a very clean m3 replica. why ruin it with wheels that are way too big for the car? IMO the biggest wheel that still looks good on e30's are 17"ers
                also, i can't believe you're actually considering trimming any of that sheet metal to make those wheels fit... especially when those panels have become so expensive/rare
                in for updates though, you seem to do good work so maybe it'll turn out looking good... i just personally think 19's look goofy on e30's
                (19x8 et40 front, 19x9.5 et 26 rear)
                [compared to your setup, the front will poke 11mm more and the rear will be sunk 7mm. so maybe you won't have to do such an aggressive roll like this dude did]
                • jburnsbmw
                  • Oct 2012
                  • 142
                  #83
                  I respect all your guys opinions and appreciate the critiquing but at the end of the day it's what I like and what makes me feel good about the build. Some people like 19's and some don't. This is similar to the look I'm trying to achieve.
                  • e30m3s54turbo
                    • Jun 2010
                    • 3290
                    #84
                    Yes. I trimmed it 21 years ago. On my other m3 I already trim it for a AC Schnitzer wheel 17x10 et17. I want run 265x40x17 if I can.
                    • 2mAn
                      Señior Mod
                      • 20989
                      #85
                      Never seen this before. Very cool. Wheel choice is a little big but this is the time to make them fit if that's what to want to run. I'm just glad to see updates
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • jburnsbmw
                        • Oct 2012
                        • 142
                        #86
                        Thanks. Yes I am in the process of making them fit. Getting ready to send the subframe and suspension parts to powder coater then once I get them back throw it all together and see what I got to do. After I have my stance disassemble put on rotisserie and blast, primer, seam seal, lizard skin sound control and lizard skin ceramic coat.
                        • Peterkaczynski
                          • Nov 2008
                          • 2587
                          #87
                          love everything about it
                          e24 e9 e30
                          IG: peterkaczynski
                          • jburnsbmw
                            • Oct 2012
                            • 142
                            #88
                            Ground control strut housing shortening
                            E46 m3 front calipers rebuild and e39 540i rear calipers. 5 lug big brake kit conversion. Elcoy's 5 lug bbk kit works excellent!
                            Condor speed shop RTAB's, fag bearings, m3 rear hub flange, 75mm turnermotorsport studs and e46 325i cross drilled rotors. All powder coating by Speedy cart coatings.
                            Thayermotorsports 3 clutch upgrade coming soon
                            Tires mounted
                            Ireland engineering camber/toe kit
                            Uscar to ev1 adapter with ID10000
                            • FreedomM3
                              • Aug 2015
                              • 191
                              #89
                              More! Awesome progress. How much did you cut off and what shocks you plan on running
                              Our RestoMod Diary!
                              El Mustache De La Resistance!
                              • jburnsbmw
                                • Oct 2012
                                • 142
                                #90
                                Jay from GC recommended cut I 1in so that's what I did. They supplied me with adjustable koni's PN on the insert is 8641 1547SPGC. Good guys over there at ground control. Set me up with 440lb up front and 900lb in rear
