Good work Bro - definitely an accomplishment. Keep it up.
E30 Oem m3 sheet metal conversion
Subscribed.How to remove, install or convert to pop out windows
Working on wheel fitment. Hopefully it will settle because I would like to it sit a little lower in front. Will have the rear subframe in by the end of weekend.
Had to use 50lb bags of horse and chicken feed to simulate weight of engine.
E30 Oem M3 Sheet metal conversion build
http://www.r3vlimited.com/board/showthread.php?t=308422
https://instagram.com/jburnsbmw/
Originally posted by markseven View PostAre you running the sway on the stiffest setting right off the bat?
Originally posted by bangn View Postyou want to go lower in the front? not keen on turning?
Got the rear on.
Got to go down in rear about a 1/2" and 3/4" in the front. I want front a little lower than rear
Got my vinyl cutter.
In the process of making a E30 solid mount short throw shifter and DSSR for project and future sales.
