E30 cabrio v12
  • jalopi
    • 2370
    Should be interesting - so what are the aftermarket performance parts options for these things? Couldn't really find anything on google last night. Also, how much longer are we talking here? 1-2" or so?
    • slammin.e28
      שמע ישראל
      • 12054
      In.
      I am slowly being woo'd to the cult of the M70 by a friend.
      • IronFreak
        • Dec 2012
        • 3702
        it's basically two m20b25 welded together......for lack of a better explanation. most any of your m20 parts would probably switch over to a point.
        Instagram @rebellionforge
        • mooseheadm5
          • Apr 2009
          • 375
          In.
          Any friend that would make you think about an M70 is, at best, a frenemy.
          -P
          Moosehead Engineering
          • mooseheadm5
            • Apr 2009
            • 375
            Few parts swap over, actually. The plug wires, cap and rotor do, but that's about it.
            It is built with the same bore, stroke, and bore spacing as an M20, though.
            -P
            • F34R
              sLaughter
              • 12385
              Wow...that is gorgeous.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • Poorboyz
                • May 2012
                • 2117
                That's looks great! How is the car going to handle with the extra weight in the front?
                Sent from my Galaxy Nexus using Tapatalk
                Rebuilding since 07/06/2016
                Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                Poorboyz Feedback Thread
                • arch4ngel
                  • Dec 2008
                  • 791
                  Stellar work so far, subd.
                  Project
                  Feedback
                  • matthugie
                    • Mar 2004
                    • 1810
                    Yep, this is gonna be good.
                    88 325is - S52 powered
                    Originally posted by King Arthur
                    We'll not risk another frontal assault, that rabbit's dynamite!
                    • ttrousdell
                      • Nov 2009
                      • 1770
                      what a beautiful job with the engine. looking forward to seeing it in your e30.
                      The Build:
                      • F34R
                        sLaughter
                        • 12385
                        It is a vert with a v12...doubt he gives a single fuck.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • CrusherCurtis
                          • 2532
                          Not a fan of m70s but that m.f.er is gorgeous.
                          • Alpina
                            • Oct 2004
                            • 838
                            Just to clear out those weight numbers ,, take a look
                            M70 is ,, 155kg 341lbs
                            S54 is ,, 148kg 326lbs
                            S38 is ,, 151kg 332lbs
                            As i had S38B38 in the car .. for 6 years the weight difference is zore to none
                            thank you for kind words,, to be honest i really like this combo my self,, i will use 4HP24 at first ,, and as soon as possible G-560
                            Running on Standalone,, mega-squirt
                            Sveinbjörn Hrafnsson
                            E30 CABRIO V12 M70B50 ///
                            ALPINA B10 BITURBO 346 @ 507
                            E34 550 V12 JML
                            Finnish wisdom : If you want to Win,, hire a Finn
                            http://alpina.123.is/pictures/
                            • stonea
                              • 2892
                              And now I want a M70.... But seriously that thing is beautiful.
                              My Garage
                              Feedback
                              Instagram: Stone.Hopkins
                              • Alpina
                                • Oct 2004
                                • 838
                                Thanks,,
                                but i would consider that,, 300 ponies and 332 lbs/ft
                                and the v12 is a 60° and dead easy to install.. but you must use 750 master etc etc
                                and cut off the pipes 3-4" from the exhaust ,,
                                i will write up when installing
                                E34 550 V12 JML
