E30 cabrio v12
  • pilotskillse30
    • Dec 2006
    • 1957
    #46
    holy baby Jesus!
    • Alpina
      • Oct 2004
      • 838
      #47
      S6S 560G on its way ,,,
      Sveinbjörn Hrafnsson
      E30 CABRIO V12 M70B50 ///
      ALPINA B10 BITURBO 346 @ 507
      E34 550 V12 JML
      Finnish wisdom : If you want to Win,, hire a Finn
      http://alpina.123.is/pictures/
      • Alpina
        • Oct 2004
        • 838
        #48
        S6S 560G vs G260/6
        overhauled Alternator,,,,,,,,,,,,,,,€€€€€€€€
        Engine mounts,,
        Manual Throttle-body
        E34 550 V12 JML
        • e30m3s54turbo
          • Jun 2010
          • 3292
          #49
          Keep the up dates coming.
          • rcsoundn1
            • Nov 2012
            • 3361
            #50
            Love
            • F34R
              sLaughter
              • 12376
              #51
              I am not feeling those engine mounts, they look like something could fail. Please do do not be offended, I LOVE this build. The mounts just look they could use a little more boxing in, for reinforcement.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • golde30
                • 11464
                #52
                I have to agree...gauge looks a little to thin.
                IG: @Baye30
                • Alpina
                  • Oct 2004
                  • 838
                  #53
                  They were made by a guy who have really knowledge in this,, that plate that bolt to the engine is 5mm thick,, the rest 3mm
                  E34 550 V12 JML
                  • Bearmw
                    • 1323
                    #54
                    That trans is massive. What does it weigh?
                    • JGood
                      • Jan 2004
                      • 7959
                      #55
                      3mm is less then 1/8". Considering the length, curvature, and lack of significant vertical support, I would use something at least twice that thick.
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #56
                        I would agree.
                        OP, where did you find the manual throttle bodies? I thought all M70 cars came with electric models?
                        • mooseheadm5
                          • Apr 2009
                          • 375
                          #57
                          I would agree.
                          They are all electric from the factory. These are modified.
                          -P
                          Moosehead Engineering
                          • Alpina
                            • Oct 2004
                            • 838
                            #58
                            I would agree.
                            Correct.. i took the motor off and changed things to get it manual,,
                            E34 550 V12 JML
                            • The Dark Side of Will
                              • Jun 2010
                              • 2796
                              #59
                              Just to clear out those weight numbers ,, take a look
                              M70 is ,, 155kg 341lbs
                              S54 is ,, 148kg 326lbs
                              S38 is ,, 151kg 332lbs
                              I'm pretty sure these weights, if accurate at all, are for completely bare long blocks (I've seen them before and know where they came from). I've weighed an S52B32 at 394 lbs fully dressed.
                              • jalopi
                                • 2370
                                #60
                                Please remake those mounts... like others have said, the material looks way too thin. I see that bending like a pretzel, especially the way the mount has to curve back what - 6"/150ish mm?
