E30 cabrio v12
  • e304me
    • Feb 2006
    • 1374
    #61
    Hey, you should redo the mounts
    • Xat1cZ
      • 2020
      #62
      The mounts look fine..
      • e30m3s54turbo
        • Jun 2010
        • 3292
        #63
        • Batz
          • Aug 2013
          • 303
          #64
          Lol so many people hating on the mounts haha
          Sent from my HTC VLE_U using Tapatalk
          • Bearmw
            • 1323
            #65
            I want to see the calculations on those mounts...till then change those mounts;)
            • e30m3s54turbo
              • Jun 2010
              • 3292
              #66
              Any up dates?
              • MattAvino
                • Jan 2011
                • 2147
                #67
                Love this build. Nice work.
                also, I'd fix the mounts.
                E30 buildy things
                http://www.r3vlimited.com/board/showthread.php?t=195286
                • Alpina
                  • Oct 2004
                  • 838
                  #68
                  Originally posted by e30m3s54turbo
                  Any up dates?
                  Oh,, yes,,
                  gearbox have arrived,, new seals,, ((replaced in and output)) clutch,, flywheel and disk + bearing is ok,, but rusty,, and i have been cleaning it
                  the bearing and slave didnt arrive ,,,,,,,,,,, ggrrrrrrrrrrr
                  but i found a bearing here,, a friend of mine have a M5 E39 and just replaced his V12 280mm UUC pressure+ plate so i grabbed this extra for free,,,,,,,, the Sachs importer is charging 500$ for it,, and 900$ for the disc,,,,,, alright baby
                  the bearing is HUMONGUS in size,, the gearbox is 60 kg,,, or 132 pounds,,,,,,,,,,,,, hehehe
                  update will follow soon + some pictures
                  Sveinbjörn Hrafnsson
                  E30 CABRIO V12 M70B50 ///
                  ALPINA B10 BITURBO 346 @ 507
                  E34 550 V12 JML
                  Finnish wisdom : If you want to Win,, hire a Finn
                  http://alpina.123.is/pictures/
                  • e30m3s54turbo
                    • Jun 2010
                    • 3292
                    #69
                    We want pics buddy!:D
                    • Alpina
                      • Oct 2004
                      • 838
                      #70
                      Da,daaaaaaaaaaaaaaaa.............................. ...........................
                      well guys
                      1 x v12 gearbox S6S 560 Getrag on M/S70
                      ahh, i wanna jump on you
                      G560 vs G280
                      N.B G280 is aprox 5cm ((2")) longer vs G260/6 ((M30B35))
                      N.B.,, G280 is on mounts and oem g280 bracket
                      bellhousings
                      OKEY....
                      SACHS,,, V12,,,,,,,,,, über über every BMW clutch i have seen so far
                      Sachs x 2 most likely the 2 titans in each class of its own
                      B10 BT clutch is the stiffest 240mm i have tried so far vs other 240mm but is made for DualMass flywheel ((Sachs 765 press is also heavy strong and stiff but made for Singlemass))
                      and then Sachs 280mm V12 clutch made for BMW,,,,,,, pretty much not the same size
                      the 240mm clutch bearing is almost a joke compared to the V12 280mm :
                      similair as G420
                      the shifting arm and selector rod may have to be shortened more or put more lenght in,, i dont know,, the gearbox came out of an UK E30 V12 conversion that was not finished
                      Tech info
                      GUIBO
                      E34 550 V12 JML
                      • e30m3s54turbo
                        • Jun 2010
                        • 3292
                        #71
                        Very interesting on the trannys difference. That throw out bearing is huge.
                        When I see your V12 motor with the paint scheme on it. I like more than your s38.:up
                        • Alpina
                          • Oct 2004
                          • 838
                          #72
                          It is to my absolute no understand why M/// Gmbh would not use this Sachs 280mm as oem for S62,, because that stock 240mm clutch is actually a shitty stuff
                          UUC are offering a special alu flywheel and use the 280mm clutch from Sachs
                          MANY E39 M5 owners have gone to that option
                          E34 550 V12 JML
                          • Alpina
                            • Oct 2004
                            • 838
                            #73
                            E34 550 V12 JML
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #74
                              Wow! I can't believe there's that much room left in front of the engine
                              • Vivek
                                attention whore/retard/bitch
                                • 6167
                                #75
                                That was my first thought also. Guess it's not much longer than an m20.
                                1992 Mauritiusblau Vert
                                2011 Alpinweiss 335is coupe
                                2002 540i/6 Black/Black
                                2003 GSX-R 750 (RIP)
