'88 325is M30 street car-->S54 -->S50 -->M54 Enduro Race car
    • 37827
    #136
    Good call on replacing those bearings!
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • wazzu70
      • Jan 2005
      • 1143
      #137
      Yikes on the bearing. Glad you decided to replace them!
      Engine bay looks good too!
      -Nick
      M42 on VEMS
      • gills
        • Jan 2006
        • 275
        #138
        wow, very good call. The fact that the rod caps are practically staring at you in the face with the pan off and on an engine stand, it'd be stupid to overlook them. I'll be sure to do them now.
        • The Dark Side of Will
          • Jun 2010
          • 2796
          #139
          Originally posted by Jb325is
          Well, thanks to Nando for suggesting I replaced my rod bearings. I was not going to do it, considering my engine has relatively low mileage (under 70k). But this was the rod side of #6
          All the way down to copper! Caught that one just in time.
          Do S54's run high oil temps, or not get enough oil to the rod bearings? Why do they (and S85's and S65's) chew up their rod bearings so quickly?
          I'm aware that the reversal loads at the top of the stroke at 8200 RPM are pretty phenomenal, but BMW also knows this and should be able to make sure those bearings get enough oil.
            • 34827
            #140
            High rpm and the rod jourbnals are a little on the small side.
              • Jun 2010
              • 2796
              #141
              NASCAR R07's (and Hondas for that matter) run Honda journals to 9,000 RPM.
                • 34827
                #142
                they're usually square or undersquare, the S54 is oversquare. and the S54 rod/stroke ratio is pretty low.
                • tinkerputzer
                  • Jun 2008
                  • 508
                  #143
                  Wow nice catch. Are s54 main bearings 180° or 360° oil groove?
                    • 34827
                    #144
                    Its the rod bearings that usually go bad
                    • tinkerputzer
                      • Jun 2008
                      • 508
                      #145
                      Yes i'm aware lol. Was just curious since the main bearings feed the rod bearings.
                        • Jun 2010
                        • 2796
                        #146
                        S54's 87x91, right? So it's undersquare.
                        Hondas have "bad" rod ratios also, and they aren't as famous for chewing rod bearings... at least not that I've heard.
                        EDIT: Higher rod ratios would certainly help, though.
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #147
                          S54 bearings are pretty skinny for the loads they see at high RPM.
                          -Nick
                          M42 on VEMS
                          • LJ851
                            • 7918
                            #148
                            Originally posted by The Dark Side of Will
                            The rod ratio shouldn't affect the cap side of the rod bearing.
                            You haven't even seen the cap side rod bearing ?
                            There is one aspect affecting bearing life left unmentioned and that is piston/rod weight.
                            Lorin
                            The M30 is God's engine.
                              • Jun 2010
                              • 2796
                              #149
                              Woops... misread the post and was thinking it was the cap side. My bad.
                              • blunttech
                                • 12850
                                #150
                                Jonathon... Rod bearings and rod bolts came in at 430pm Friday Ill ship Monday am
                                sales@blunttech.com
                                www.blunttech.com
                                Like us on Facebook
