'88 325is M30 street car-->S54 -->S50 -->M54 Enduro Race car
  • sam_
    • May 2014
    • 630
    #256
    sweet!
    1991 325i
    flickr
    @sambhaskins
    • FredK
      • 14764
      #257
      Nice rear brake setup! Do the calipers bolt right up, without modification?
      • E30 Wagen
        • Jul 2005
        • 3435
        #258
        Also interested in know this. Fitment looks great.
        edit: and sorry for asking but what's your front five lug setup? I don't feel like going through the thread.
        My Feedback
        • henryki
          • Jun 2013
          • 960
          #259
          Just went through every page of this thread, sub'd.
          • Jb325is
            • 2137
            #260
            I have the kit from "nasieg" to run e46 stuff, so in the front I have spindle sleeves and e36 m3 hubs, everything else is still e30. The kit comes with caliper brackets front and rear. They were supposed to fit e46 calipers in the rear, but that didn't work, then I tried some e36 m3 calipers, which didn't work, and finally I picked up the 540i calipers, which seem to fit. You can also retain the e-brake with these rotors, but I didn't because my ebrake sucked anyways and I didn't feel like ordering new shoes and stuff. I also have a pressure limit valve for the rear feed line, hoping that will work to fine tune the bias.
            20140911_202428 by braswell.jonathan, on Flickr
            20140911_202611 by braswell.jonathan, on Flickr
            20140911_203203 by braswell.jonathan, on Flickr
            20140911_204957 by braswell.jonathan, on Flickr
            While I'm waiting on my last caliper bracket I finised tidy'd up the wiring in my engine bay, changed my clogged heater core, and re-did the heater hoses tonight.
            I cut off the e46 m3 heater hoses and bought some e39 528 hoses. You have to re-use the quick clip things from the e46 obviously, and make sure to remember which is which because the one that fits on the aluminum coolant pipe will leak if you put it on the steel pipe.
            20141001_201602 by braswell.jonathan, on Flickr
            20141001_211801 by braswell.jonathan, on Flickr
            20141001_211823 by braswell.jonathan, on Flickr
            - '88 m54 coupe
            <3
              • 34847
              #261
              Need to ditch that hot air intake. :p
              Looks sweet! So i'm guessing your issues are fixed now?
              • DER E30
                • Sep 2013
                • 2349
                #262
                That 5 lug kit looks pretty neat!
                I need one of those motors!
                -Christian
                • pandaboo911
                  • 2070
                  #263
                  How did you run your coolant lines to relocate the expansion tank? I need to do that.
                  • Jb325is
                    • 2137
                    #264
                    The s54 pipe comes out on that side, so you just run the hose back there. You can see it in the passenger side view. I had to run the return from the radiator under the intake back there though, which isn't ideal. It's zip tied to the upper radiator hose, not really any way to make it look good
                    Nando, seems like it is fixed. Hopefully I'll know by the end of the day
                    - '88 m54 coupe
                    <3
                    • JGood
                      • Jan 2004
                      • 7959
                      #265
                      Another option is to use an e34 535i/540i overflow hose, it has a 180* then 90* bend. Run it over to the driver side fender with the throttle cable, then back to the firewall, behind the cover.
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • dude8383
                        • Jan 2005
                        • 10387
                        #266
                        Man that bay is tidy! Can we get some friggin vids of this thing running already?!
                        Why was it cutting out at 6k, seems like you fixed it but curious what is was.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #267
                          Pretty sure your Hcore hoses are backwards...
                          Check Us out on Facebook
                          Full Product Line Tuning
                          • Jb325is
                            • 2137
                            #268
                            True, I forgot about those things.
                            Soon! And I'm not sure, you'd have to ask Dave and Nando, it was some sort of ecu coding issue.
                            I had them the other way before and it didn't flow. I replaced the heater core and valve and swapped the hoses, we'll see, they're not too hard to swap so it's ok
                            - '88 m54 coupe
                            <3
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #269
                              Top port on core is outlet. 1000% confirmed, I have a thread about this somewhere on here
                              • Jb325is
                                • 2137
                                #270
                                According to this, top pipe (#7) is the return. Don't think that's the best place for my temp sensor though
                                - '88 m54 coupe
                                <3
