Wow, torques everywhere!
'88 325is M30 street car-->S54 -->S50 -->M54 Enduro Race car
dang. It just goes to show, building an exhaust that makes more power than stock is hard, but building one that is worse is pretty easy!Comment
I'm pretty sure it is. merge placement can have a huge impact, as well as his 3.5" piping. he makes a little more top end, but sacrifices low end.
I wonder though, is the area lost on the torque curve greater or less than the area gained in the HP curve?Comment
another comparison: Bone Stock Car to SupaFast 344whp car
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
I think this also!
THat "bone stock" car has at least 20whp more than every "stock" m3 I've seenI can't remember one making more than ~280whp stock.
Its all pointless discussion anyway, dynos show increases, not "true" whp-Christian
'37 Chevy pickup, the über projectOriginally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
The bone stock is tuned :P. Refer to my dyno thread. It did 276whp 100% stock.
All the stock cars i see pretune do 260-280whp.
And i know 'every dyno measures differently' but i have 50+ cars on that thread all on the same dyno ;)Last edited by 328ijunkie; 06-11-2015, 09:12 AM.
people like to play internet dyno experts, but really Dynojets are pretty consistent and hard to fudge.Comment
Nice hp & torque curve. Must be a blast to drive rippin it at 8k.
Did I miss a video....???Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
Just thought I'd update this. The car has taken a few steps backwards in awesomeness, but I'm doing what I want to do with it. I'll get some better pictures as things progress a little more. The interior is gutted and ready to finish cage, just waiting on some free time so I can get the suspension done to make it a roller.
Shitty 325is parts car on the right, m20 bottom end of left. Head is off getting machined.
spece302 by Jonathan braswell, on Flickr
Booster back in, lines for ABS back in.. I wish I hadn't cleaned up the engine bay so much, I'm definitely lacking some bracketry
spece301 by Jonathan braswell, on Flickr
- '88 m54 coupe
<3Comment
brake bias question
hows your brake felt, after used e46m3 front and e46 325 rear?
good bias or too much front bias?
what's brake MC that you used?[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction FeedbackComment
I didn't plan on updating this thread, but things have changed a lot. After all but finishing the spec e30 build, I decided/was convinced that having a spec e30 and not being able to afford to run in consistently for a whole season would be pretty frustrating. At the same time, some friends that already run spec e30 were looking to build a faster e30 for endurance racing. They had an s50, I had a chassis with a nice cage, so we decided to build a proper e30 race car.
The baseline formula is as follows:
s50
Nasieg 5 lug (e46 m3/e39 540i brakes)
MCS 2-Way Remote Res dampers (600/800 springs/GC Plates/AKG Poly everything)
17x9 Apex ARC-8
Later on:
-Aero that actually works (not random panels cut off and pieces of plastic riveted to the bumpers)
-Spherical rear subframe with adjustment (right now bending trailing arm to specs and no adjusters)
-Adjustable pick-up points to play with geometry
-S54 again!
We pretty much have everything,except for free time at the moment, my summers are pretty busy. Also, we just keep running into dumb issues... Anyone have any input on these?
1. Caster/Wheel placement. I'm like 1/2" forward in the wheel well right now and I'm not sure why. I have brand new control arms, brand new AKG offset bushings, not sure what subframe I have in the car but I will need to check and make sure it isn't bent. This is my first time using offset bushings in stock lollipops, the car had Treehouse stuff before.. Whats the deal?
2. Steering coupler binding after e36 rack install. I re-built the coupler with a Dungeon motorsport spacer kit, the spacers and hardware are corret, but I'm bottoming out the coupler and feel it bind in the steering. I could probably gring out a little pocket in the coupler to clear, but would like to find another solution first. Anyone had this issue?
I'll figure this stuff out, just haven't gotten the chance to look much into it and won't be able to for a week or so... So any input from someone who has encountered similar issues would be appreciated in the meantime.
20160715_165324 by Jonathan braswell, on Flickr
20160801_201955 by Jonathan braswell, on Flickr
<3Comment
